  3. Probing all terminal currents
  • Views 14763
fetuestc
fetuestc over 12 years ago
Looking for a skill code to list all terminal currents (including all hierarchy levels). I figure that there exist at least 3 ways to extract this terminal list: (1) schematic hierarchy, (2) netlist, (3) psf file. Either is fine, but advantage of extracting those terminal names from psf is preferable since these are all available terminals for sure.
Thanks!
    You ought to be able to use:
    outputs(?type "I" ?result 'tran)
    to get this from the PSF, but this appears to be broken in IC61X (CCR 1158354). It works in IC5141 (assuming that the output format is psfbin).
