  3. Getting schematic instances from multiple open schemati...
  • Replies 9
  • Subscribers 150
  • Views 19274
Getting schematic instances from multiple open schematics
shajujan
shajujan over 12 years ago
I want write a skill routine that lets the user interactively select instances from multiple schematics & get those instance names. I tried geAddSelectPoint(), but that will prompt the user to select instances only from the current cellview. I tried dbGetOpenCellViews(), but that will get me all the open cellviews in memory including the ones not open currently.
Any ideas on how to get started will be much appreciated.
Shaju
  • shajujan
    On 2nd thoughts the more accurate description is a routine to add every instance that a user selects to a list (across multiple schematics) as he/she is selecting it. I need the instName, cellName & libName (s) to use in another routine.
    Shaju
  • tweeks
    tweeks over 12 years ago
    There are at least two solutions:
    1. Since geGetSelSet() only handles one window at a time, temporarily rebind the left mouse button to run a custom procedure that selects and then records the selection in a list.
    2. Let the user select everything they want, then iterate through every open window using hiGetWindowList(), calling geGetSelSet() on each, concatenating the results.
  • shajujan
    Thanks. Both are excellent suggestions. But I'm doing this to select instances for an ADE-XL session. So I found an easier way to do this & tired using "asiSelectInst" with this code:
        ;get a unique form handle
        win  = sprintf( nil "%s" hiGetCurrentWindow() )
        form = concat( 'iphdcopTabForm substring(win 8 strlen(win)) )
        ;top level form
        unless( boundp(form)
            hiCreateAppForm(
                 ?name          form
                 ?formTitle    "Inphi DC Operating Point Report"
                 ?initialSize   290:200
                 ?buttonLayout  list(
                                    'Empty
                                     list( 'Create\ Report 'IPHdcopTabCB )
                                     list( 'Close 'hiFormClose )
                 ?fields        list(
                                    hiCreateStringField(
                                            ?name           'cell
                                            ?prompt         "Test Bench"
                                            ?defValue       axlGetSessionCellName( ses )
                                            ?editable       nil
                                    hiCreateCyclicField(
                                            ?name           'test
                                            ?prompt         "Select Test"
                                            ?choices        cadr( axlGetTests(axldb) )
                                    hiCreateRadioField(
                                            ?name           'mode
                                            ?prompt         "Sort by"
                                            ?choices        list("Corner" "Instance")
                                            ?defValue       "Corner"
                                    hiCreateButton(
                                            ?name           'select
                                            ?buttonText     "Select Instance"
                                            ?callback       "asiSelectInst('inst ?form form)"
                                            ?name           'inst
                                            ?prompt         "Instances"
        form->asiSession = asiGetCurrentSession()
        hiDisplayForm(form)
     But I get this warning when I hit the select button & no instances are selected.
     *Warning* No window and/or doneProc argument passed to
              "astiSelectInst", selection not started
    Any ideas?
    Shaju
    A couple of things. First the callback should be:
                                             ?callback       "asiSelectInst('inst ?form symeval(form))"
    and in fact it might make sense to avoid it needing the "form" global variable, so using:
                                             ?callback       sprintf(nil "asiSelectInst('inst ?form symeval('%s))" form)
    might be better still.
    Secondly it requires the design to be open in a tab. It doesn't do that automatically. I can't see a way of ensuring that happens without using private APIs (and I don't really have time now to debug this fully as I'm travelling at the moment). So I suggest you contact customer support for this.
    Thirdly, your form stores asiSession on the form symbol - you might want to use:
    symeval(form)->asiSession=sevEnvironment(asiGetToolSession(ses testName))
    and have this updated based on your cyclic field (as a callback) so that it reflect the "right" session for the test.
    Not fully debugged, as I said, but I did a little experimentation.
  • shajujan
    Andrew,
    Thanks for the response.
    symeval(form)->asiSession = sevEnvironment( asiGetToolSession(ses symeval(form)->test->value) )
    *Error* eval: undefined function - asiGetToolSession
    Shaju
     Shaju,
    Apologies - that was a typo. It should have been axlGetToolSession.
  • shajujan
    New code. Same problem. Any help/advice appreciated.
     ; Create Menus
    procedure( IPHdcopTabForm()
        prog(( ses axldb hist win form sym )
        ;get db & history for this session
        ses   = axlGetWindowSession()
        axldb = axlGetMainSetupDB( ses )
        hist  = axlGetCurrentHistory( ses )
        ;check for an open ade-xl session
        unless( ses
            message( sprintf(nil "No active ADE-XL session\n") "ERROR" )
            return(nil)
        ;make sure that an active setup is loaded
        if( hist == 0 then
            message( sprintf(nil "No active setup loaded in current ADE-XL session\n") "ERROR" )
            return(nil)
        ;top level form
            hiCreateAppForm(
                 ?name          form
                 ?buttonLayout  list(
                                    'Empty
                                     list( 'Select\ Instances "asiSelectInst('inst)" )
                 ?fields        list(
                                            ?name           'cell
                                            ?editable       nil
                                            ?name           'test
                                            ?callback       sprintf( nil "IPHdcopTestCB(symeval('%s))" form )
                                    hiCreateRadioField(
                                            ?name           'mode
                                            ?prompt         "Sort by"
                                            ?defValue       "Corner"
                                            ?name           'inst
                                            ?prompt         "Instances"
                                            ?defValue       "*"
        sym  = symeval( form )
        sym->asiSession = sevEnvironment( axlGetToolSession(ses sym->test->value) )
        hiDisplayForm(form)
        return(t)
    ; Callback for 'test' field
    procedure( IPHdcopTestCB(iphdcopTabForm)
        prog(( ses test )
        test   = iphdcopTabForm->test->value
        printf( "DEBUG> %s\n", test )
        iphdcopTabForm->asiSession = sevEnvironment( axlGetToolSession(ses test) )
  • shajujan
    Does asiSelectInst() work for ADE-XL or it is a ADE-L only function?
    Yes, but it requires the test design to have been opened in a tab first, because it doesn't tie up the design with the ADE session id otherwise.
