  3. Create Text view and edit it
  • Views 18650
ivick
ivick over 12 years ago
How can I create a new Text and edit it by using skill?.
Actually I have already tried with the following code (I am using IC6):
 cv= dbOpenCellViewByType(Cell_Lib Cell_Name "myViewName" "text" "w" )
 port = outfile( cv~>fileName )
 fprintf( port "This is a test\n" )
 close( port )
 dbSave(cv)
However after the first line I have the following warning and the rest of code don't work:
" *WARNING* (DB-270208): dbOpenCellViewByType: unrecognized database viewType 'text' "
    See this comp.cad.cadence post I made a few years back (and this earlier post). It includes some SKILL abOpenTextCellView.ils - which is for opening text cellviews. As the earlier post explains (although the newer post has a newer version of the code), in the past you used to be able to use dbOpenCellViewByType to open textual cellViews, but it was really a bug - the text view has no "database" and so it makes no sense to use dbOpenCellViewByType on such a view.
  • ivick
    Thanks, I have already tested the  abOpenTextCellView however I have the following error:
    *Error* eval: undefined function - make_abTextCellView
    Do you have some idea why is not working?
    Ivick
    Presumably you omitted this line:
    (defstruct abTextCellView libName cellName viewName fileName fullPath mode port)
  • ivick
     Thanks very much for your support, it worked for me.
    Ivick.
