  3. Display flyline using SKILL .
  • Views 16761
marbs
marbs over 12 years ago
 Hi All,
 I would like to ask, how to display flyline in vxl layout using SKILL ?
 For example I would like to display the flyline of the netname "vss" .
 By using SKILL code, how to do it ?
 I'm using IC615.
Best regards,
Marben
  • skillUser
    skillUser over 12 years ago
    Hi Marben,
    There are a few SKILL commands for controlling the flight line display:
    lxToggleShowIncompleteNets()
    lxToggleShowAllIncompleteNets()
    lxShowHideIncompleteNets()
    There may be more, these are just the ones I have found so far...
    Hope this helps!
    Lawrence.
    How about something like this:
    geDeselectAll()
    hsmSelect(?type 'net ?name "vss")
    geDeselectAll() ; otherwise you're seeing the selected net rather than the highlighted marker...
    The lxShowHideIncompleteNets() will toggle the visibility of the highlight, but  you could just use the hsmSelect if seeing the flightlines for the selected net is enough.
  • marbs
     It works like a charm .
     I am looking for these for many days without luck,
     finally I got it. Flylines is very useful to view connections in layout.
    Thank you very much !!!
     Best regards,
     Marben
  • marbs
    Hi Lawrence,
    Thanks very much for your prompt reply.
    Best regards,
    Marben
