  3. OCEAN/SKILL XML database
  • Views 1416
Alex Vasjanov
Alex Vasjanov over 12 years ago
Hello cadence community,
just wondering, is there any way of getting an XML database containing all (or maybe most widely used) OCEAN/SKILL functions? Maybe such databases are present in cadence install directory?
I have created such for OCEAN language but included only the most popular procedures (in my use) and some SKILL commands that I use, but it would be nice to have other procedures. It is possible to update the already created database but it will be a painful experience :).
This is a thing of convenience and not crutial. For those who don't know the purpose for this database - it can be added as a *.lang file in gedit text editor (which I use for OCEAN/SKILL scripting).
Aleksandr
  • skillUser
    skillUser over 12 years ago
    Hi Alex,
    Actually yes there is, well, kind of.  With the documentation we also have the "Finder" database which is a cut-down version of the documentation in a SKILL-esque format.  If you look in the installation directory, the finder database is found as follows:
    ls <CDS installation dir>/doc/finder/SKILL
    AMSDesigner/                   User_Interface/     coreskill/   se/
    Component_Description_Format/  VHDL_Integ/         dfIIconfig/  skartistref/
    Connectivity_to_Schematic/     Verilog_Integ/      edif200/     skcompref/
    Custom_Layout/                 adexlSKILLref/      libManager/  transrefOA/
    DFII_SKILL/                    aelref/             migrate/     verin/
    DIVA/                          anaPlaceGXL/        oceanref/    vivaskill/
    DRACULA-GUI/                   caiuser/            oss/         vpsl/
    Relative_Object_Design/        compXLhelp/         parasim/
    Skpcellref/                    comphelp/           pcellref/
    Tech_File/                     constraintsCustom/  plot/
    Inside each of the directories (I've highlighted the core SKILL and OCEAN directories) there are one or more *.fnd files which are in a SKILL type of syntax (parentheses group each function item, its function header interface and its description).  You will need to do some conversion to get this into an XML format - luckily they are structurally quite similar...
    Hopefully this helps you.
    Lawrence.
