  3. User Preference
  • Subscribers 150
  • Views 18297
User Preference
gorilla
gorilla over 12 years ago
Hi,All
On IC 615,before I begin my work,I have to set the Option->User Prefence ,select the nil or true. I want to do it with a skill progress,Does anyone know how to do it?
gorilla
    Gorilla,
    What are you actually setting on this form? You didn't say. Then I can give you an answer.
    You can work this out by using the following process. Before making the change, go to Options->Save Defaults. Set:
    • Tools to Save: All possible tools
    • File Status: Overwrite
    • Save To File: ./before
    Hit Apply. Then bring up the Options->User Preferences form and make the change you want (OK the form). Then do the Save Defaults again, but chnge the Save to file to "./after".
    Then in UNIX do: "diff before after". For me I just got:
     11717c11717
    < ui    ciwRetainUniqueCmds     boolean t
    > ui    ciwRetainUniqueCmds     boolean nil
    This is because I just turned off the "Retain Unique Commands" checkbox on the form. This tells me that I need to add:
    to my ~/.cdsenv file, or if I want it in my .cdsinit, I would write this as:
      envSetVal("ui" "ciwRetainUniqueCmds"  'boolean nil)
    Hope that helps you to figure it out yourself.
    Kind Regards,
  • gorilla
    Andrew,
    I am very sorry for my very late reply. I just want to choose User preference->Options Displays When Commands Starts->true.
    I don't want to choose it everytime I begin my work.
    Gorilla.
  • dmay
    dmay over 12 years ago
    If you had followed Andrew's suggestion, you'd have found this one difference in your .cdsenv:
    ui showOptionForms boolean t
    As he suggested, you could then run this command:
    envSetVal("ui" "showOptionForm" 'boolean t)
    or
    envSetVal("ui" "showOptionForm" 'boolean nil)
    Derek
    "Teach a man to fish" as the saying goes...
  • gorilla
     I get the fishing ,thanks
