  3. Translation of SRFI-26
  • Views 15013
tweeks
tweeks over 12 years ago
I am translating SRFI-26/cut.scm into SKILL++.  (See here for a description of how it's supposed to work, and here for a test suite).
This looked about right:
(define_syntax cut_internal
  (syntax_rules (X XXX)
    ((_ (slot_name ...) (proc arg ...))
     (lambda (slot_name ...) ((begin proc) arg ...)))
    ((_ (slot_name ...) (proc arg ...) XXX)
     (lambda (slot_name ... @rest rest_slot)
       (apply proc arg ... rest_slot)))
    ((_ (slot_name ...) (position ...) X se ...)
     (cut_internal (slot_name ... x) (position ... x) se ...))
    ((_ (slot_name ...) (position ...) nse se ...)
     (cut_internal (slot_name ...) (position ... nse) se ...))))
(define_syntax cut
  (syntax_rules ()
    ((cut slots_or_exprs ...)
     (cut_internal () () slots_or_exprs ...))))
It works on some cases:
((cut times 2 X) 3) => 6
((cut times 2 XXX) 2 3 4) => 48
((cut list 1 X 3 XXX) 2 4 5 6) => (1 2 3 4 5 6)
But this case fails:
((cut list 1 X 3 X 5) 2 4) => (1 2 3 2 5)
That should have been (1 2 3 4 5).
Can anyone help me fix the bug?
  • tweeks
    It appears define_syntax is not generating unique identifiers as it would for the SRFI-26 code. In particular,
    (cut list 1 X 3 X)
    Is supposed to expand to
    (lambda (x1 x2) ((begin list) 1 x1 3 x2))
    But instead it's expanding to
    (lambda (x x) ((begin list) 1 x 3 x))
    Which is an error in Guile, but SKILL++ allows it, binding both occurances of x to the first argument. (Interestingly, Emacs Lisp also permits (lambda (x x) ...), but it chooses the second argument for the x's.)
    Anyway, after several hours of getting nowhere, I gave up and used defmacro with explicit gensyms:
    (defmacro cut_internal (s p @rest r)
      (cond ((null? r)
             `(lambda (,@s) ((begin ,(car p)) ,@(cdr p))))
            ((equal? r '(XXX))
             (let ((v (gensym)))
               `(lambda (,@s @rest ,v)
                  (apply ,(car p) ,@(cdr p) ,v))))
            ((eq? (car r) 'X)
             (let ((v (gensym)))
               `(cut_internal ,(append1 s v) ,(append1 p v) ,@(cdr r))))
            (t
             `(cut_internal ,s ,(append1 p (car r)) ,@(cdr r)))))
    (defmacro cut (@rest slots_or_exprs)
      `(cut_internal () () ,@slots_or_exprs))
    Hygienic macros: nice idea, but they don't work in SKILL++ (yet?).
    Tom,
    I'm afraid define_syntax is private - quite probably because it is not a complete implementation. I believe it's used internally for a couple of things in SKILL, but it was probably not finished - and may have limitations. I've not investigated the implementation to check it out properly.
    If you want define_syntax supported, I suggest you contact customer support. The same for hygienic macros. I've not found any requests for either - so they won't get implemented unless you ask. Then we can get R&D to look whether define_syntax can be finished and made public, and whether we can implement hygienic macros.
  • tweeks
    Case 45592745 submitted.
