  3. Modify a parameter value in an input.scs file
  • Views 16696
insaf
insaf over 12 years ago
Hi all,
I want to modify a parameter value in an input.scs file directly with a command function which allows to overwrite into this file and change the value of Vdd for exemple without crushing the rest of the file.
 simulator lang=spectre
 global 0
 parameters Vdd=2.8 SwPresto=1 Vb=0 Vg=1.664 gateresglobal=0 \
 lsimpackaging=0 matching=1 swjunexpglobal=1 swleakglobal=1 swdg=0 \
 mimglobal=1 globaldtaplus=0 hdiprocessssmc=0 "
Is there any Skill command that allows to do this?
Thanks in advance.
Best Regards,
Insaf
  • insaf
    insaf over 12 years ago +1
    Hi Lawrence, Thank you again for your interest. I was actually looking for the following command to modify a parameter value in my file. sh(sprintf( nil " sed - i s/Vdd=2.8/Vdd=newValue/g $filename " …
  • skillUser
    skillUser over 12 years ago
    Hi Insaf,
    I think that the way to go about this is to use the OCEAN command desVar() to change the value of a design variable.  You can then also run or re-run a simulation from OCEAN commands.  OCEAN is the SKILL scripting interface to the Analog Design Environment (ADE).
    Hope this helps to answer your question.
    Lawrence.
  • insaf
    Hi Lawrence,
    Thanks Lawrence for your response.
    but, all i need is to modify systematically the parameters value in this file with a routine by incrementing Vg and Vdd and load it in each time to be used in a specific application without running any simulation.
    I hope that my explanation was clear for you so that you can help me.
    thanks a lot.
     Best Regards,
    Insaf
  • insaf
    Hi Lawrence,
    sh(sprintf( nil " sed -i s/Vdd=2.8/Vdd=newValue/g $filename " ))
    Best Regards,
    Insaf
