  3. Naming contacts in Skill
  • Views 15211
wakeup12
wakeup12 over 12 years ago
 I have a PMOS pcell designer using GUI. Then, I converted it into SKILL file.
 However, I would like to name the contacts as Source and Drain to do a routing later on.
 Could someone give me an example on how to do that in SKILL? Thank you,
    Do you really mean that you want to name the contacts? Surely you just want pins on the metal (and possibly the diffusion regions) for the source and drain? If so, can't you just create those pins in the layout editor and have the stretch lines affect them too? I'm not sure what use naming the contacts would be.
  • wakeup12
    Thank you for your answer and sorry for delay. E.g. I would like to name the contact on the left as T11 and on the right as T12 If I create another transistor they should be named as T21 and T22 so that for example I can connect them with a path by just providing the names e.g. drawPath(T11 T21)
