  3. Blockage layers info
  • Views 16748
psill000
psill000 over 12 years ago
How do I get the list of blockage layers from the techfile, library or cellview.
Is this correct way to toggle the visiblity and selectablity by using the commans below.
pteSetVisible("Blockages;Routing Blockage;M1" nil "Objects")
pteSetSelectable("Blockages;Routing Blockage;M1" nil "Objects")
Would the pin blockage be about the same on get the list and toggling the visiblity and selectablity?
Paul
  • skillUser
    skillUser over 12 years ago
    Hi Paul,
    To get a list of the layer-purpose pairs that are of type blockage, one way is as follows:
    tf = techGetTechFile(ddGetObj("myTechLibName"))
    blockageLPs = setof(lp tf~>lps lp~>purpose=="blockage")
    => (db:0x18e15d68 db:0x18e15dd0 db:0x18e15e38 db:0x18e15ea0 db:0x18e15f08
         db:0x18e15f70 db:0x18e15fd8 db:0x18e16040 db:0x18e160a8 db:0x18e16110
         db:0x18e2c680 db:0x18e2c6d8
    blockageLPs~>name
    => ("Metal1" "Via1" "Metal2" "Via2" "Metal3"
         "Via3" "Metal4" "Via4" "Metal5" "Via5"
         "Metal6" "Cont"
    This is a list of LP objects, i.e. each item on the list is a layer-purpose pair object in the technology file. From this then you know which layers have blockages defined for them (as layer-purpose pairs in the techfile, I'm not talking about which layer blockages might exist in a design).  I haven't looked into your second question - the commands look about right but I've not tested. Not sure what you mean about "the pin blockage", sorry.
    Hope this helps!
    Lawrence.
