  3. Updating Pcell Parameters through script
  • Views 17175
harishgurram
harishgurram over 12 years ago
I am using PCells for my design. So I am setting some parameters for all the pcells.
Letus say I am using finger width as 10microns. and some others parameters( gate width, fingers, contacts..)
 So When I am trying to modify these parameters using change properties form in GUI it is working fine.
But when I have tried to modify using script, the parameter values are setting as like in gui. The cell is not looking like the one which I had done using gui. and If i modify anything(any parameter) then these two are looking similar
I am using the script like this say my pcell is pch_mac, I will select that and
geGetSelSet()~>wf = "10"  ;(this is finger width)
geGetSelSet()~>nf  = "2" ;(this is fingers)
So my question is whether we have to say apply these parameters after setting all or is there anything like refreshing ?
I hope you understood my point..
    There are numerous similar questions in the forums. For example http://www.cadence.com/Community/forums/p/27540/1328025.aspx#1328025 . The key is that you need to call the CDF callbacks - because you have some parameters which are derived from others, and it's these which are controlling the pcell, not the values you're entering (at least this seems to most likely explanation to me).
    The other post mentions what you need to search for. There is code mentioned in various places in this forum - either abInvokeCdfCallbacks.il or CCSinvokeCdfCallbacks.il . These will take care of calling the callbacks for you.
    Kind Regards,
  • bvasu
    bvasu over 12 years ago
    We are unable to find that code. Please share it ..Please
    See my response to your other post.
