  3. How can I get the data of what layer is selected in IC6...
  • Views 15006
How can I get the data of what layer is selected in IC616_X
DesmondLiu
DesmondLiu over 12 years ago
    I tried to use pteGetSelection() but it only works for "Grids" & "Objects". What is exactly the function for me to return a value of which layer is selected right now in Data Palette? I also tried to find some leLSW* function, but I didn't find any possibilities.
    Thank you.
    pteGetSelection("Layers") only works if you have enabled the "Multiple selection" option on the palette Options form.
    If you want the current entry layer, use leGetEntryLayer() .
  • DesmondLiu
        Thank you Andrew for your prompt response and it's prefectly matched what I wanted to know.
