  3. Help with skill code to convert pin labels to pin textd...
  • Views 17836
Help with skill code to convert pin labels to pin textdisplays
pham777
pham777 over 12 years ago
Pins in VXL are created with create label option as "Label" instead of "Text Display".  I wonder if there is a skill code to covert all pin "Label" back to pin "TextDisplay".
I am using cadence IC615
Thanks a lot,
HP
  • skillUser
    skillUser over 12 years ago
    I'm not sure about SKILL to convert Labels to Text Displays (I don't think I've written any, nor have I seen existing code for this), but one thing that may be of interest, there is a .cdsenv variable for IC616 and ICADV121 that allows you to specify whether pins will be one or other (or there is a "Both" setting too):
     layout pinDefaultObjectType     cyclic "Text Display"
    I hope this helps a little.
    Lawrence.
  • pham777
    Hi Lawrence,
    There is one skil code to convert pin textdisplays to pin labels which I found on Cadence Online Help archive as follows:
    * DISCLAIMER: The following code is provided for Cadence customers to use at *
    * their own risk. The code may require modification to satisfy the *
    * requirements of any user. The code and any modifications to the code may *
    * not be compatible with current or future versions of Cadence products. *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING WITHOUT *
    * LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES OF MERCHANTABILITY *
    * OR FITNESS FOR A PARTICULAR USE. *
    ;**************CCSreplaceTextDisplay.il*****************************************
    procedure(CCSreplaceTextDisplay()
    let((cv labelId)
    cv = geGetEditCellView()
    foreach( shape cv~>shapes
    when( shape~>objType=="textDisplay"
    printf("Found textDisplay %s %L at %L\n" shape~>owner~>name shape~>lpp shape~>xy)
    labelId=dbCreateLabel(cv
    shape~>lpp
    shape~>xy
    shape~>owner~>name
    shape~>justify
    shape~>orient
    shape~>font
    shape~>height
    ); dbCreateLabel
    leAttachFig(labelId shape~>parent)
    dbDeleteObject(shape)
    ); when
    ); foreach
    ); let
    ); procedure
    I'm not sure how to do the other way around (from pin labels to pin textdisplays)
    regards,
    HP
