  3. CallBack not working for 'hiCreateStringField'
  • Views 6381
Mani1989
Mani1989 over 12 years ago
       I am trying to create a GUI which is similar in structure to that of cdlOut GUI. I added a 'Button' widget to invoke the callback to a string field which i created. I want to make even the manual updation of the field possible and It needs to update some other fields through 'modifycallback'. Now the thing is manual updation of the stringField is working fine and the 'modifyCallback' also working correctly. But if i try to update its value through the button widget which i created, Field is not getting updated. Can anyone please help me with this problem?
Thanks and Regards,
Manikandan Kuzandhaivelu
  • skillUser
    skillUser over 12 years ago
    Hi Manikandan,
    I'm sure there are folks that can help you with your problem, but without providing specific details of the code, what answer do you expect?
    I suspect that you are doing it incorrectly  <--  this answer meets the level of detail provided in the question, but it is not useful.
    Please provide specific details and then someone will probably be able to help you.
    Best regards,
    Lawrence.
