  3. skill command for adding an ocean measurements file to ade...
  • Views 15463
skill command for adding an ocean measurements file to ade xl output
Meny Lea
Meny Lea over 12 years ago
Hi all,
I have a short ocean measurements file that  i need to load into ade xl output section from a skill script.
I need somthing that is similar to the right click and "load ocean script" , provide a pointer, and than all expressions are derived.
I couldnt find a skill command that allow me to add an ocean script ( just like the axladdoutputexperssion command) .
and idea?
thx
meny
    Hi Meny,
    As I mentioned in my direct email to you, I took a quick look and the function that axlAddOutputExpr() calls looks as if it supports adding "OCEAN" scripts (I think), but there's no public interface to add ocean script measurements. So you should contact customer support and then they (we) can file an enhancement CCR for this.
    Kind Regards,
