  3. Copy and Rename of a Pin in Symbol
  • Subscribers 150
  • Views 16029
AnilDS
AnilDS over 12 years ago
Can someone help me with the skill commands to copy and rename a pin.
Problem Def: I need to add a new pin in all my symbols. The symbol view can have different pin shapes (round, square, hexagon etc ). The new pin should have the same shape as the rest of the pins in the symbol.
 I was thinking of copying an existing pin and changing the name. I managed to copy the pin using schCopy but i wasnt able to rename the pin.
-Anil
  • NiallDuncan
    NiallDuncan over 12 years ago
    If you managed to copy the pin, then I expect you have the pinID of the new pin?
    You can rename the pin name using:
    pinID~>pin~>term~>name = "MyNewPinName"
    Niall
