  3. Can macros be lexically-bound?
  • Views 14925
tweeks
tweeks over 12 years ago
When I try to defmacro within a let, I get a warning:
*WARNING* (def): treated as top-level definition - localMacro
and the macro is bound at the top-level. Is there any way to hide a macro definition?
I thought about using namespaces, but I don't want all the identifiers in my code looking like:::this. Also, you can only import names into the toplevel namespace! Yes, you can un-import them when done, but this implies you need an unwind-protect to make sure the unuseNamespace() happens if there's an error, and I doubt it even works with SKILL++ environments anyway....
On a related subject: are syntax transformers created by define_syntax always global?
    Tom,
    No - there is an enhancement CCR, 813051, asking for an implementation of macrolet in SKILL. You should contact customer support and request an enhancement (which can be duplicated with that CCR) since currently the only requester is internal.
    I suspect that define_syntax (which is private as I've pointed out before) is also not using lexical scoping (I didn't check, since it's private and there are already some limitations, as has been discussed before). It's only really used by SKILL Lint at the moment.
  • tweeks
    Thanks Andrew.
    Case Number: Case 45601923
