  3. prob signals from inside a block with Spectre
  • Views 16465
mlea
mlea over 12 years ago
Hi All,
 Im attaching a short include file to my netlist:
  ITF0 (set_up_tf\<0\> hold_tf\<0\> setup_min_tf\<0\> hold_min_tf\<0\>  I7.XI35\MM44:G vcca  \
I7.XI35\MM54:G vcca) su_hd_vmon scale_to_units=1e-9 clk_n_factor=0.5  \
data_n_factor=0.5 min_max_measure_start_t=20n data_edge=0  \
clk_edge=1
ITF0   is a verilogA block that get 4 inputs and has for output ( 4 wires bus). Two of the inputs are vcca, and the other two are :  I7.XI35\MM44:G &  I7.XI35\MM54:G , which are names of nets from inside a DSPF.  I can even see these signals in the results browser or calculator or ADE-XL(  I do save these signals in advance). The thing is that all outputs of the verilogA are dead (the 4 wire bus).
 When I place the same unit ( actual symbol ) on the same TB, in the same run ( running stimultanslly)  with  wires connected ( by name ) to the extracted block pins( in this case I7 which sit in top level)
I do get the all signals. I also verified that the inputs signals are identical between these two cases
It look like the connections of the inputs to the verilogA cell are not define right. In Pre layout it works fine.
This way ( below) it works fine, but in this method I don’t really probe the real location on net that I need, since in RC extraction the net is segmented into different segments because of the series resistors.
I6 (set_up\<0\> hold\<0\> setup_min\<0\> hold_min\<0\> clk_int vcca d_net2 \
        clk_edge=1
I would need you advise here ..
  • mlea
    actully I think Ive got it - the problem is with the inputs name. one cant just bring out signals from inside a block no matter if it extracted or not, with out a proper pin or probe.
    I will give it a try.
  • mlea
    H again,
    I found out that I had few warnings msg in spectre log that I over looked.
    it turned out that spectre couldnt find such an hirarchy :I7.XI35\/MM44\:G . I tried few other syntax types - no use.
    it make sense that it would be :  I7.XI35.MM44.G - but its not..
    meny.
    Meny,
    Seeing the DSPF would make it much easier to understand what the problem is. It's perfectly legal to do "out of context" connections (i.e. hierarchical paths) in spectre, but you have to remember that the "hierarchical" net names within the DSPF aren't really hierarchical - they are pseudo-hierarchical - they have mapped the previous hierarchy into a flat namespace.
    Please log this via customer support.
  • mlea
    Andrew,
    thx - I uploaded the DSPF file into the system.
    Im intersted in I7.XI35.MM44.G
