  3. standalone SKILL binary command line parsing weirdness
  • Subscribers 150
  • Views 14669
tweeks
tweeks over 12 years ago
Check this out: create a SKILL script called myScript.il containing the following lines:
#!/usr/bin/env skill -64
(println (argv 1))
Watch what happens when you try to pass arguments:
tweeks@awesome> myScript.il -foo bar
"-foo"
*Error* load: can't access file - "bar"
Does anyone else think it's weird that the standalone SKILL executable interprets any arguments that don't start with a dash as a filename to load?
Besides being inconsistent with how interpreters usually work (bash, tcl, python, etc.), this curious feature makes it impossible to create dash options that take un-dashed arguments; e.g. you can't do this:
myScript.il -log ~/logs/myLog.log -mode r ~/tmp/stuff.oa
I'm sure there is a good reason (possibly long forgotten in SKILL's murky past....)
Also, the "-help" option appears to be broken:
tweeks@awesome> skill -help
*WARNING* Unsupported option "h" is ignored
*WARNING* Unsupported option "l" is ignored
*WARNING* Unsupported option "p" is ignored
What about "-e"? What does that do?
  • tweeks
    With further experimentation, I discovered the following Fun Facts:
    1. If you call exit() at the end of the script, SKILL does not attempt to load() the command line arguments as files.
    2. If an unhandled error() occurs, SKILL will attempt to load() the command line arguments as files.
    3. The interpreter prints a free newline for you.  (You can print a delete character to erase it, though.)
    Conclusion: the standalone SKILL binary is a little weird, but if you're careful, you can still get it to do what you want.
