  3. Instantiate a device with terminal names (SKILL)
  • Subscribers 150
  • Views 16820
PietroUser
PietroUser over 12 years ago
I have the following code to instantiate an nmos transistor in a schematic:
 ; Open the CV to create
cvId=dbOpenCellViewByType("Test_Structures" "Rects1" "schematic" "schematic" "w")
 ; Open the master cell to instatiate
mosId = dbOpenCellViewByType("analogLib" "nmos4" "symbol" "schematicSymbol" "r")
Inst=dbCreateInst(cvId mosId nil '(0 0) "R0" 1)
;schCreateWire( cvId "draw" "full" list(0:0 1:0) 0.0625 0.0625 0.0 )
;schCreateWireLabel(
;to save and close:
dbSave(cvId)
dbClose(cvId)
I would like to add wires and labels to obtain the result as in the attached picture.
Pietro
  • skillUser
    skillUser over 12 years ago
    Hi Pietro,
    I don't have an exact example to hand, but the code section below may help you
    inst=dbCreateInst(cvId mosId nil '(0 0) "R0" 1)
    ;; put the wire stubs in yourself using schCreateWire in 'direct' mode
    ;; then create the labels - you might wish to attach the labels to the
    ;; wire segments, in which case, use schCreateWireLabel as above and
    ;; provide the wire as the 'd_glue' argument
    ;; this just creates labels right on the center of the instance pins
    transform=inst~>transform
      foreach( instTerm inst~>instTerms
        foreach( pin instTerm~>term~>pins
          pinCenter=centerBox(pin~>fig~>bBox)
          dbCreateLabel(cellView list("text" "drawing")
            dbTransformPoint(pinCenter transform)
            strcat("n" instTerm~>name)
            "centerCenter"
            "R0" "stick"
    	0.0625
          ); dbCreateLabel
        ); foreach pin
      ); foreach instance terminal
    The main thing here is that the pin center is obtained in the code above - you would need to work out which direction to extend the wire in and perhaps place the label along the wire, but the above should give you a good starting point.
    Lawrence.
