  3. How to let the messages not show in shell terminal when...
  • Views 16345
How to let the messages not show in shell terminal when use ipcBeginProcess ?
Charley Chen
Charley Chen over 12 years ago
Hello All,
I use  ipcBeginProcess to do something , but I don't want the messages show in xterm ,
How to do it ?
Thank you,
Charley
    Charley,
    If you're using ipcBeginProcess, then either you can use the "asynchronous" form and provide functions to consume the stdout and stderr output, or you can use the synchronous apprach and use ipcReadProcess. Output shouldn't appear in the xterm, since both stdout and stderr get sent to Virtuoso.
    So I don't understand your problem.
  • Charley Chen
    I use  ipcId = ipcBeginprocess("strmin ..."  nil dataHandle errorHandle log) ,
    I see the message sent to the xterm .
    Thank you,
    Charley
  • Charley Chen
    Hi Andrew ,
    I found the problem and know how to solve  it. , it's the log file  is used , it will sent message to xterm .
     If I use  ipcId = ipcBeginprocess("strmin ..."  nil dataHandle errorHandle log) ,  it will sent message to xterm
    If I use  ipcId = ipcBeginprocess("strmin ..."  nil dataHandle errorHandle ) ,  it won't sent message to xterm
    Thank you,
    Charley
    Charley,
    Presumably you didn't actually use those calls, because the function has a capital P  in Process, the second argument should be a string (e.g. "") rather than nil, and the log file name is the 6th argument, not the 5th (the 5th is an exit handler).
    If I use:
    procedure(MyDisplayStuff(cid data) printf("STUFF: %L\n" data))
    procedure(MyExitHandler(cid status) printf("EXITED: %L\n" status))
    ipcBeginProcess("/bin/ls" "" 'MyDisplayStuff 'MyDisplayStuff 'MyExitHandler "log")
    Then I get nothing in the terminal, but I do get a file called log. If the file "log" is not writable for some reason, I get this in the xterm:
      Server: could not open/create logfile log
    Is that what you mean?
  • Charley Chen
    Andrew ,
    Thank you for correct me the usage and explain it.
    Charley
