  3. How to get correct ProcessID when launchipcBeginProcess...
  • Views 16013
How to get correct ProcessID when launchipcBeginProcess ?
Charley Chen
Charley Chen over 12 years ago
Hi All ,
 cid=ipcBeginProcess("runSimulation")
 ;Wait for the Job to start
ipcWaitForProcess(cid)
 ;Get Unix PID
pid=cid->processPid  ;;pid = 876
 In xterm , I type  'top' , I can't see 876 , But I can see  PID = 877
Thank you,
Charley
  • skillUser
    skillUser over 12 years ago
    Hi Charley,
    Unless I am mistaken, runSimulation is a script which invokes spectre, so you are probably asking about the pid of the spectre process which was spawned from the script.  In that case, you might use something like pstree to obtain the pid of the process(es) that the script started, since from the SKILL side, ipcBeginProcess only started one job/script and does not know about anything invoked by that job. The pstree command is a UNIX/Linux command, so you would need to use something like ipcBeginProcess again, in order to be able to read back the results.
    Hopefully this will help you to find what you need?
    Lawrence.
  • Charley Chen
    Hi Lawrence ,
     The pstree command is helpful and that's what i want.
    Thank you for.help.
    Charley
