  3. How to re-set "XST_IN" after launch virtuoso ?
  • Views 1116
Charley Chen
Charley Chen over 12 years ago
Hi All ,
In .cdsinit file set the following;  IC 6.1.6
envSetVal( "xstream" "XST_IN" 'string "/home/user1/StreamIn.template" )
I Re-Set in CIW , But when I launch Stream In GUI , it is still the previous value)
envSetVal( "xstream" "XST_IN" 'string "/home/user2/StreamInNew.template" )
How can I Re-Set & the value will be changed ?
Thank you,
Charley
    Charley,
    Instead of using envSetVal, use:
    xstInSetField("templateFile" "StreamIn.template1")
    This works.
  • Charley Chen
    Hi Andrew ,
    It works.
    Thank you for help.
    Charley
