  3. Parameterize a schematic pcell
  • Views 17855
KoVe
KoVe over 12 years ago
I made a schematic pcell for some schematic using technology pcell - the MOS transistors. When I enter a paremeter in the cfd field, the following warning is printed:
*WARNING* (DB-270002): ("times" 0 t nil ("*Error* times: can't handle (\"Wn\" * 1.0)"))
Instead of filling in the value of Wn, that is set in ADE L, the string "Wn" is passed.This causes:
  cdfFormatFloatString( sprintf(nil "%g" (cdfParseFloatString(widN)*factor) ) "n")
to isue a warning.
I understand why, because the type of the cdf parameter widN is string. But how do I make it possible for my pcell to be parametrized, like e.g. transistor pcell provided by the PDK I am using?
Thanks!
Relevant code:
load("../scripts/CCSinvokeCdfCallbacks.il")
load("../scripts/invChainCCScallbackPatternsToIgnore.il")
let( (library cell pcellID parameters)
library="Playground"
cell="TIC"
unless(ddGetObj(library)
    error("Couldn't open library %L" library)
; Schematic
pcellID=pcDefinePCell(
    list( ddGetObj(library) cell "schematic" "schematic")
        (widN             string        "120n")
    let(    ( cvIDnmos )
      cvIDnmos = dbOpenCellViewByType( libname nchCellName "symbol" nil "r" )
      for( iterator 0 numberOfStages-1
        factor = stageRatio**iterator
        nmos = dbCreateParamInst( pcCellView
            cvIDnmos
            nil    2*iterator+6*ss:0     "R0" 1
            list(
                list("width"    "string"    cdfFormatFloatString( sprintf(nil "%g" (cdfParseFloatString(widN)*factor) ) "n") )
            t
    CCSinvokeCdfCallbacks(pcCellView ?callInitProc t ?useInstCDF t)
    dbClose(cvIDnmos)
    ); end let
);pcDefinePCell
dbSave(pcellID)
dbClose(pcellID)
let( (cellID cdfID)
    unless(cellID = ddGetObj( library cell )
        error("Could not get cell %s." cell)
    when(     cdfID = cdfGetBaseCellCDF( cellID )
        cdfDeleteCDF( cdfID )
    cdfID  = cdfCreateBaseCellCDF( cellID )
    cdfCreateParam( cdfID
        ?name            "widN"
        ?type            "string"
        ?defValue        "120n"
        ?units            "lengthMetric"
        ?parseAsNumber    "yes"
        ?prompt        "gate width of first nmos"
        ?display        "t"
);let cdf
);let
    Rather than trying to evaluate the parameter (which you really can't, because if it has pPar() in, they are occurrence-specific and pcell evaluation is only unique for each combination of input parameters, so it would be incorrect to evaluate them assuming a particular occurrence path), it would be better to use:
                    list("width"    "string"    sprintf(nil "pPar(\"widN\")*%g" factor))
    There's no need for widN to be a pcell parameter in this case. If this was your only pcell parameter, there's no need for it to be a pcell at all... (I'm assuming you've just simplified your example though to remove the unnecessary complexity when asking this question).
  • KoVe
    Thank you, Andrew. The solution you propose works. I did indeed simplify the code to reduce complexity (and to anonymize the PDK I am using).
    I can now use the variables in ADE L, but in ADE XL the default value is used (I tried both the design variables and global variables fields). Any idea why and how to solve this?
    Thanks.
    I can't think why that would happen. You probably need to either post a simple example (as an attachment, using the Options tab), or better still go to customer support so that we can see your real data.
    Kind Regards,
