  3. Propagate and annotate DC operating points to schematic...
  • Views 15471
Propagate and annotate DC operating points to schematic pcell from one level down hierarchy
Oleg Si
Oleg Si over 12 years ago
I have created a symbol which is a schematic pcell that contains one transistor one level down hierarchy. When i run DC simulation all the DC operating points (i.e. id, vgs, vds, gm, gds) and terminal voltages and current are displayed at transistor level. I'm trying to propagate and annotate all that simulation data one level up to the symbol level.
What I have tried so far:
I have added ILLabels to symbol (cdsParam(1), cdsParam(2),...)
Modified the CDF using following syntax (not sure what is appropriate syntax for above params):
This is an example that I obtained from documentation, which doesn't seem to work either.
opParamExprList    (
    ("resistor" "OP(root(\"R4\") \"res\")")
Tool Versions:
 IC12.1-64b.500.6
Spectre: 6.2.1.310
Any help is greatly appreciated.
