  3. How to sort a file(list) alphabetically using skill
  • Views 3152
pham777
pham777 over 12 years ago
I have a text file such as:
M7(pin)(#37)
M7(drawing)(#37)
M6(drawing)(#36)
RMDMY(drawing5)(#116)
VAR(drawing)(#92)
RH(drawing4)(#117)
prBoundary(boundary)(#235)
How can I sort these outputs alphabetically using skill in order to have:
M6(drawing)(#36)
M7(drawing)(#37)
M7(pin)(#37)
RH(drawing4)(#117)
VAR(drawing)(#92)
Thanks a lot,
HP
    If it is just sorting a file, I'd probably use the UNIX sort command.
    If you need to so it in SKILL, you could use infile to open the file and then have a while loop using gets with the result being cons'd onto a list, and then use sort() on the resulting list. Pretty easy.
