  3. conc functions
  • Subscribers 148
  • Views 15994
conc functions
DE202408202727
DE202408202727 over 12 years ago
I'm using Allegro Skill but I think this might be a better place to post this question.
In the following code I would expect y to be unchanged and remain at (3 4). However it becomes (3 4 5 6). Is this expected behavior?
x = tconc(nil 1)
y = list(3 4)
lconc(x y)
lconc(x list(5 6))
    Yes, this is expected behaviour. lconc is aiming to be as efficient as possible and so does not copy the second argument - it is documented as being destructive.
  • DE202408202727
    Thanks Andrew. The documentation is not clear on that.
    Would you expect lconc using a copy on the second list to still be markedy more efficient than append?
    It's hard to compare. The expense of append is with copying the first list (the second list is not copied and so is just a matter of setting the cdr of the last element of the copy of the first list to point to the second list). With lconc, getting to the end of the first list is cheap, but having to copy the second list would be more expensive than just having to iterate to the end of the second list (which is what lconc normally has to do to preserve the integrity of the lconc structure).
    So the efficiency depends on the relative lengths of the two lists.
