  3. Pin or signal naming promotion from PCELL connectivity ...
  • Subscribers 150
  • Views 16674
Pin or signal naming promotion from PCELL connectivity information
sanramz
sanramz over 12 years ago
  I have generated layout using Virtuoso XL and SDL. Is there any way to promote the net/pin names of those PCELLS from the connectivity information it associates??
Santhosh
  • tweeks
    tweeks over 12 years ago
    What is SDL?
    What do you mean by "promote"?
    I didn't understand the question either. SDL probably means Schematic Driven Layout. There is the Connectivity->Nets->Propagate, but if using VLS XL this shouldn't be necessary because the connectivity would come from the connectivity source (the schematic).
    So I don't really understand what is being asked (which is why I didn't answer it earlier).
  • sanramz
     When I generate the Layout from schematic, all the devices/pcells have the connectivity information associated with it. This connectivity can be seen by NAVIGATOR or ANNATOTION BROWSER.
    When I check any one PCELL properties (using css()~>?? ) associated with it, the properties of that PCELL are as mentioned below.
    css()~>??
    (db:0x169edb92 cellView db:0x169e9f92 objType "inst"
        prop
        (db:0x169e2ca1 db:0xec13d8a2 db:0xec13d8a1 db:0xec13d8a0 db:0xec13d89f
    db:0xec13d89e db:0xec13d89d db:0xec13d89c db:0xec13d89b db:0xec13d89a
    db:0xec13d899 db:0xec13d898 db:0xec13d897 db:0xec13d896 db:0xec13d895
    db:0xec13d894 db:0xec13d893 db:0xec13d892 db:0x169e2cff db:0x169e2cfe
    db:0x169e2cfd db:0x169e2cfc db:0x169e2cfb db:0x169e2cfa db:0x169e2cf9
    db:0x169e2cf8 db:0x169e2cf7 db:0x169e2cf6 db:0x169e2cf5 db:0x169e2cf4
    db:0x169e2cf3 db:0x169e2cf2 db:0x169e2cf1 db:0x169e2cf0 db:0x169e2cef
    db:0x169e2cee db:0x169e2ced db:0x169e2cec db:0x169e2ceb db:0x169e2cea
    db:0x169e2ce9 db:0x169e2ce8 db:0x169e2ce7 db:0x169e2ce6 db:0x169e2ce5
    db:0x169e2ce4 db:0x169e2ce3 db:0x169e2ce2 db:0x169e2ce1 db:0x169e2ce0
    db:0x169e2cdf db:0x169e2cde db:0x169e2cdd db:0x169e2cdc db:0x169e2cdb
    db:0x169e2cda db:0x169e2cd9 db:0x169e2cd8 db:0x169e2cd7 db:0x169e2cd6
    db:0x169e2cd5 db:0x169e2cd4 db:0x169e2cd3 db:0x169e2cd2 db:0x169e2cd1
    db:0x169e2cd0 db:0x169e2ccf db:0x169e2cce db:0x169e2ccd db:0x169e2ccc
    db:0x169e2ccb db:0x169e2cca db:0x169e2cc9 db:0x169e2cc8 db:0x169e2cc7
    db:0x169e2cc6 db:0x169e2cc5 db:0x169e2cc4 db:0x169e2cc3 db:0x169e2cc2
    db:0x169e2cc1 db:0x169e2cc0 db:0x169e2cbf db:0x169e2cbe db:0x169e2cbd
    db:0x169e2cbc db:0x169e2cbb db:0x169e2cba db:0x169e2cb9 db:0x169e2cb8
    db:0x169e2cb7 db:0x169e2cb6 db:0x169e2cb5 db:0x169e2cb4 db:0x169e2cb3
    db:0x169e2cb2 db:0x169e2cb1 db:0x169e2cb0 db:0x169e2caf db:0x169e2cae
    db:0x169e2cad db:0x169e2cac db:0x169e2cab db:0x169e2caa db:0x169e2ca9
    db:0x169e2ca8 db:0x169e2ca7 db:0x169e2ca6 db:0x169e2ca5 db:0x169e2ca4
    db:0x169e2ca3 db:0x169e2ca2 db:0x1c938ab0 db:0x1c938abc db:0x1c938ac8
    db:0x1c938ad4 db:0x1c938ae0 db:0x1c938aec db:0x1c938af8 db:0x1c938b04
    db:0x1c938b10 db:0x1c938b1c db:0x1c938b28 db:0x1c938b34 db:0x1c938b40
        ) bBox
        ((0.5 -1.411)
    (1.0 -1.065)
        ) children
        nil groupMembers nil isAnyInst t
        isShape nil matchPoints nil net
        nil parent nil pin nil
        purpose "cell" textDisplays nil assocTextDisplays
        nil markers nil figGroup nil
        baseName "|I868.1|MP0" cellName "pmos" instHeader
        db:0x169ef493 instTerms
        (db:0x169e6e94 db:0x169e6e93 db:0x169e6e92) libName "16nm_master"
        master db:0x169e9792 name "|I868.1|MP0" numInst
        1 viewName "layout" conns
        mag 1.0 orient "R0" status
        nil transform
        ((0.742 -1.315) "R0" 1.0) xy
        (0.742 -1.315)
        cluster nil blockages nil physOnly
        nil source "netlist"
    But here it is not indicating any Source/Gate/Drain connection information. How can I get that info??
    Santhosh
  • dmay
    dmay over 12 years ago
     The information is there, you just need to go deeper. Notice that there are three "instTerms":
     instTerms     (db:0x169e6e94 db:0x169e6e93 db:0x169e6e92)
    Try:
    css()~>instTerms~>??
    foreach(it css()~>instTerms printf("inst name: %s   term name: %s  net name: %s\n" it~>inst~>name it~>term~>name it~>net~>name))
    Derek
  • sanramz
    Thanks alot Derek!!
     It helped me.
