  3. Drawing path using SKILL
  • Replies 8
  • Subscribers 150
  • Views 23541
wakeup12
wakeup12 over 12 years ago
 I have modified a SKILL file to draw a path from one point to another. However, this function takes two arguments: starting and ending point.
 I was wondering if it is possible to write the corner points to make it really look like a path.
 Here is the code:
 pastebin.ubuntu.com/.../
 Currently, when we specify another location after the end point, we see a result like the right side of this image:
However, I would like to make it look like the one on the left using our function if possible.
Thank you for your response.
    dbCreatePath accepts a list of points - so you could just give a list of three points. It's not at all obvious to me why your code is creating a pcell, when the pcell doesn't appear to have any parameters (so it's a not-very-parameterized parameterized cell!). Couldn't you just draw the path using dbCreatePath?
  • NiallDuncan
    NiallDuncan over 12 years ago
     The easiest way to do this is to gather more points before you run the function. Instead of having a "begin" and "end" point, modify the function so that it accepts a list of points:
     List_Of_Points = list((0:0) (10:0) (10:10) (10:30) (30:30))
    procedure( drawPath( List_Of_Points layer @optional (width 0.5))
    Then place these into your dbCreatePath command as:
    dbCreatePath( cvID list(pcLayer pcPurpose) List_Of_Points width "truncateExtend" )
     If you are adament that you must use the function you have, then I would recommend extending the end point by "width/2" before you run the function
  • NiallDuncan
     [Sorry, had not seen Andrews response when I replied. Agree with him entirely.]
  • wakeup12
    Thank you for answers.
     We are first creating transistor with a procedure and this procedure returns some values, for example.
     One of the values is contacts[ array which contains the contact coordinates.
     Assuming we created two transistors with these commands:
    1. tCreate(1 1 0 0 "nmos")
    2. tCreate(1 1 0 -5 "nmos")
    contacts[0:0] (first transistor, first contact on the left) gives ((-0.798 0.05)) while contacts[1:0] (second transistor, first contact on the left) gives ((-0.798 -4.95)).
    To connect these two, I write: drawPath(contacts[0:0] contacts[1:0] "MET1")
    However, I was not able to use the built-in method to do the same.
     Thank you again.
    This doesn't make a lot of sense. I can't see how calling a function that creates a pcell with some fixed values helps you in any way. If you just want to create a path, why can't you just use dbCreatePath with a list of points? It's not difficult... the list of points could be derived from the contacts array.
  • wakeup12
    Thank you for the answer.
    Actually the reason of using the method was to create somehow a layout in the background and call these functions to create a design.
    Let's say we will use OCEAN to load those files and call them one by one.
    According to your answer, it seems there is a way to create a layout and use it to add new devices. As you can see from the function, currently we are creating a dummy layout not to cause a syntax error (which is not well written), but using the currentCellView to create paths and transistors.
    Could you give a small example or link so that I could do the following?
    1. Create a layout in the background
    2. Use this layout to create paths using those point formats: '((x1 y1)) '((x2 y2)) '((x3 y3)) ... etc (we can also use (x1:y1) format, but I am not sure how I can convert our contacts[ array to this format.
    Thank you very much.
    Your question is really confusing. OCEAN is for simulation and nothing to do with creating layout!
    Without knowing precisely how your contacts array is created, it's hard to advise how to convert it into a list, but you wouldn't be using '((x1 y1)). That's a quoted list which would mean that variables aren't evaluated.
    Maybe showing you an example would give you enough:
    defMathConstants('CCFmath)
    procedure(CCFdrawSillyPath(cv layer width periodLength pathAmplitude @optional (nPoints 100))
    let((x y points)
      for(i 0 nPoints
        x=i*float(periodLength)/nPoints
        y=pathAmplitude*sin(i*CCFmath.PI*2/nPoints)
        points=cons(list(x y) points)
      dbCreatePath(cv layer points width)
    cv=dbOpenCellViewByType("myLib" "myCell" "layout" "maskLayout" "a")
    CCFdrawSillyPath(cv "Metal2" 1.0 100.0 20.0)
    dbSave(cv)
    dbClose(cv)
    An utterly silly example, but it should show you how to create a list of points (where each point is a list of an x and a y value), and then open a cellView, create some shapes, save and close it. No need to have any windows open when you do this.
    You could do this with "virtuoso -nograph" so no need to have any graphics either.
  • wakeup12
    Woow. This was a great example :). Thank you very much.
