  3. How to flip an instance SIDEWAYS using skill
  • Subscribers 150
  • Views 23528
BALBOA
BALBOA over 12 years ago
HI,
 I need a command or a program to flip the selected instance sideways without changing the orientation.
Girish
  • tweeks
    tweeks over 12 years ago
    instance->transform = dbConcatTransform(instance->transform list(0:0 "MY" 1.0))
     Although the downside of doing that is that it flips around the Y axis, which might not be what you want.
    You might find this useful:
    /* abFlip.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jun 22, 2005
    Modified   Nov 18, 2009
    By         A.D.Beckett
    Functions to do flipping (and rotation) in place. Examples
    of usage:
    abFlip()
      - does a flip horizontally relative to the centre of the selected figures
    abFlip(?relativeTo 'lowerLeft)
      - does a horizontal flip relative to the lower left corner
    abFlip(?orient "MX" ?relativeTo 'upperRight)
      - does a vertical flip relative to the upperRight corner
    abFlip(?orient "MY" ?relativeTo 'upperRight ?mode 'copy)
      - does a horizontal flipped copy relative to the upperRight corner
    abFlip(?orient "R90" ?relativeTo 'refPoint)
      - does a 90 degree rotation relative to the reference point (often
        the + key on the numeric keypad).
    In this function:
    ?orient can be set to:
        "MY" - mirror in Y axis (i.e. horizontal flip) (default)
        "MX" - mirror in X axis (i.e. vertical flip)
        "R90" - 90 degree anti-clockwise rotate
        "R180" - 180 degree anti-clockwise rotate
        "R270" - 90 degree clockwise rotate
        "R0" - no rotation (not much point!)
        "MYR90" - mirror in Y axis and rotate by 90
        "MXR90" - mirror in X axis and rotate by 90
    ?relativeTo can be set to:
    'centerBox - center of selected figures (default)
    'lowerLeft - lower left of selected figures
    'lowerRight - lower right of selected figures
    'upperLeft - upper left of selected figures
    'upperRight - upper right of selected figures
    'refPoint - the reference point
    'origin - the cellview origin (i.e. 0:0)
    ?mode can be set to
    'move - (the default) flip during a move
    'copy - (the default) flip during a copy
    ?noSnap can be set to t if you don't want it to
    snap the origin of the flip
    abSetRefPoint(?relativeTo 'upperLeft)
      - set the ref point relative to the selected objects
    The ?relativeTo has the same meaning as for abFlip()
    SCCS Info: @(#) abFlip.il 11/18/09.11:21:07 1.3
    *         (abFlip [?orient "MY"] [?relativeTo 'centerBox]         *
    *           [?mode 'move] [?win windowId] [?noSnap nil])          *
    * Flips the selected objects (if any) relative to somewhere, with *
    *       a particular orientation. Can either copy or move.        *
    *      For details, see the comments at the top of this file      *
    (procedure (abFlip @key (orient "MY") (relativeTo 'centerBox)
                       (mode 'move) noSnap
                       (win (hiGetCurrentWindow)))
      (let (bbox figs origin transform)
           (setq figs (geGetSelSet win))
           ; work out the origin of the transform
           (setq bbox (abFindBBox figs))
           (setq origin
                 (case relativeTo
                       (centerBox (centerBox bbox))
                       (lowerLeft (lowerLeft bbox))
                       (lowerRight (list (xCoord (upperRight bbox))
                                         (yCoord (lowerLeft bbox))))
                       (upperLeft (list (xCoord (lowerLeft bbox))
                                        (yCoord (upperRight bbox))))
                       (upperRight (upperRight bbox))
                       (refPoint (leGetRefPoint (geGetEditCellView win)))
                       (origin (list 0 0))
                       (t (error "Unknown ?relativeTo mode; must be one of 'centerBox, 'lowerLeft, 'lowerRight, 'upperLeft, 'upperRight, 'refPoint, 'origin"))
           (when origin
                 (unless noSnap
                         (setq origin
                               (list
                                (times (round (quotient
                                               (xCoord origin)
                                               (getq win xSnapSpacing)))
                                               (yCoord origin)
                                               (getq win ySnapSpacing)))
                 ; Combine the transform to do a shift to the origin,
                 ; rotate/flip, and then shift back again
                 (setq transform
                       (dbConcatTransform
                        (dbConcatTransform
                         (list (mapcar 'minus origin) "R0")
                         (list 0:0 orient)
                        (list origin "R0")
                 ; Then either move or copy all the figures
                 (foreach fig figs
                          ; Don't move or copy the shape if it's attached
                          ; to something else that is also selected
                          (unless fig~>parent && geIsFigSelected(fig~>parent)
                            (case mode
                              (move
                                (dbMoveFig fig (dbGetq fig cellView) transform))
                              (copy
                                (dbCopyFig fig (dbGetq fig cellView) transform))
                 t
    *   (abSetRefPoint [?relativeTo 'centerBox] [?win windowId])   *
    *     Set the reference point relative to somewhere on the     *
    *                        selected set.                         *
    (procedure (abSetRefPoint @key (relativeTo 'centerBox)
      (let (bbox figs origin)
           ; Work out the new reference point
           (setq origin
                 (case relativeTo
                       (origin (list 0 0))
           (when origin
                 (leSetRefPoint (geGetEditCellView win) origin)
    /* abZoomSel.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd
    Machine    SUN
    Date       May 20, 1993
    Modified   A.D.Beckett
    By         Feb 04, 1998
    Various procedures for zooming to selected set, and for
    zooming to probed things.
    SCCS Info: @(#) abZoomSel.il 11/20/08.15:26:22 1.3
    *          (abExtendBBox bbox @rest xy)          *
    * procedure to take a bounding box and extend it *
    *              by a list of points.              *
    (procedure (abExtendBBox bbox @rest xy)
      (let (minx maxx miny maxy coord)
           (if (and (listp xy)
                    (listp (car xy))
                    (listp (car (car xy))))
               (setq xy (car xy)))
           (if (null bbox)
               (setq bbox (list (car xy) (car xy))))
           (setq minx (xCoord (lowerLeft bbox)))
           (setq maxx (xCoord (upperRight bbox)))
           (setq miny (yCoord (lowerLeft bbox)))
           (setq maxy (yCoord (upperRight bbox)))
           (foreach coord xy
                    (if (lessp (xCoord coord) minx) (setq minx (xCoord coord)))
                    (if (lessp (yCoord coord) miny) (setq miny (yCoord coord)))
                    (if (greaterp (xCoord coord) maxx) (setq maxx (xCoord coord)))
                    (if (greaterp (yCoord coord) maxy) (setq maxy (yCoord coord))))
           /* return the new bbox */
           (list (list minx miny) (list maxx maxy))))
    *      (abEnlargeBBox bbox percent)       *
    * extend the bounding box by a percentage *
    (procedure (abEnlargeBBox bbox percent)
      (let (extendX extendY)
           /* calculate extensions */
           (setq extendX
                 (quotient
                  (times
                   (difference
                   percent)
                  200.0))
           (setq extendY
                 (quotient
                  (times
                   (difference
                   percent)
                  200.0))
           /* return the enlarged bounding box */
           (list
            (list
             (difference (xCoord (lowerLeft bbox)) extendX)
             (difference (yCoord (lowerLeft bbox)) extendY))
            (list
             (plus (xCoord (upperRight bbox)) extendX)
             (plus (yCoord (upperRight bbox)) extendY)))))
    *          (abBBoxToPoints bbox)          *
    * Convert a bounding box to a point list. *
    (procedure (abBBoxToPoints bbox)
      (list
       (lowerLeft bbox)
       (list (xCoord (lowerLeft bbox)) (yCoord (upperRight bbox)))
       (upperRight bbox)
       (list (xCoord (upperRight bbox)) (yCoord (lowerLeft bbox)))))
    *                   (abFindBBox select)                   *
    * Find the bounding box of the list of objects passed in. *
    *     Copes with partially selected objects as well.      *
    (procedure (abFindBBox select @optional forceWholeObject)
      (let (bbox)
           (foreach dbp select
                    (if (or forceWholeObject (geIsFigAllSelected dbp))
                        (setq bbox (abExtendBBox bbox (dbGetq dbp bBox)))
                        (let (pointList)
                             /* generate a point list for object, either directly or from bbox */
                             (unless (setq pointList (dbGetq dbp points))
                                     (setq pointList (abBBoxToPoints (dbGetq dbp bBox))))
                             /* scan two lists, extending bbox if point is selected */
                             (mapc '(lambda (point bool)
                                            (when bool (setq bbox (abExtendBBox bbox point))))
                                   pointList
                                   (geGetSelSetFigPoint dbp)))))
           /* return bounding box */
           bbox))
    *    (abZoomSel @optional (select nil))    *
    * Zoom in on the selected set (no overlap) *
    *  Copes with partially selected objects   *
    (procedure (abZoomSel @optional (select nil))
      (let (bbox wind forceWholeObject)
           /* get current window */
           (setq wind (hiGetCurrentWindow))
           /* get selected set if not passed in */
           (if select
               (setq forceWholeObject t)
               (setq select (geGetSelSet wind)))
           (setq bbox (abFindBBox select forceWholeObject))
           (if bbox
               (hiZoomIn wind (list (geEditToWindowPoint wind (lowerLeft bbox))
                                    (geEditToWindowPoint wind (upperRight bbox))))
               (hiDisplayAppDBox
                ?name 'abZSnothingSelected
                ?dboxBanner "Nothing Selected"
                ?dboxText "Nothing is selected for Zoom Selected"
                ?dialogType hicMessageDialog
                ?buttonLayout 'Close))))
    * (abZoomSelPlus @optional (select nil)) *
    * same as abZoomSel, but enlarges by 10% *
    (procedure (abZoomSelPlus @optional (select nil) (percent 10))
           (if select
           (if bbox
               (progn
                (setq bbox (abEnlargeBBox bbox percent))
                                     (geEditToWindowPoint wind (upperRight bbox)))))
               (hiDisplayAppDBox
    *                       (abZoomOrig win)                       *
    *         simple function for zooming in at the origin         *
    (procedure (abZoomOrig win)
      (hiZoomIn win '((-0.2 -0.2) (0.2 0.2))))
    *           (abZoomProbes @optional (window (hiGetCurrentWindow)))            *
    * Zoom into probed objects. Works with nets and instances in extracted views. *
    *         Haven't tested with all objects, but seems to work so far!          *
    (procedure (abZoomProbes @optional (window (hiGetCurrentWindow)))
      (let (cellView probedObjects probedFigs)
           (setq cellView (geGetEditCellView window))
           ; find all the probed objects in the current window
           (setq probedObjects
                 (setof obj (foreach mapcar probe
                                     (geGetAllProbe window) (getq probe objectId))
                                      (equal (dbGetq obj cellView) cellView)))
           (setq probedFigs
                 (foreach mapcan object probedObjects
                          (case (dbGetq object objType)
                                ("sig"
                                 ; combine the figures
                                 (foreach mapcan net
                                          ; get from sigs to member nets
                                          (foreach mapcar memNet
                                                   (dbGetq object memNets)
                                                   (car memNet))
                                          (dbGetq net figs))
                                ("net"
                                 (dbGetq object figs)
                                (t (list object))
           ; zoom into them
           (abZoomSel probedFigs)
