  3. SKILL namespaces vs SKILL++ environments
  • Views 16825
tweeks
tweeks over 12 years ago
I've been playing around with namespaces and environments recently, and have observed the following
pros and cons:
  • SKILL++ Environments
    • Pros:
      • Easy to use.
      • Well-documented in the SKILL++ manual and the Scheme literature.
      • No need to enumerate the names to be hidden (as with addToNamespace).
      • Low-impact on the global environment.
      • Can use toplevel('ils theEnvironment(myFunc)) to set the toplevel evaluation context inside an environment.
      • Implementation is mature.
      • Can programmatically get a list of all symbols in an environment.
    • Cons:
      • Can't put a macro in an environment.
      • No builtins for importing, exporting, and shadowing.
      • Can't put a class or a generic function in an environment.
  • SKILL Namespaces
    • Pros:
      • Works for all kinds of names, including macros.  (But not classes and generic functions, which are always global.)
      • Comes with builtins for importing, exporting, and shadowing.
    • Cons:
      • Confusing to use, because it works by altering how the reader maps textual names to symbol objects.
      • Does not currently interact smoothly with infix operator conversion.
        • E.g. Define your own "plus" in a namespace, shadowImport it, and read("1 + 1").  You will get the builtin plus primop rather than your redefined plus.  But if you read("(plus 1 1)"), you will get the redefined plus!
      • Heavy impact on global environment due to useNamespace().  Need to use unwindProtect() to ensure namespaces are unused if there is a load() error, lest other SKILL developers on the other side of the world (who don't even know about namespaces) become very confused.
      • Need to enumerate every single name that goes in the namespace.  If you forget one, that name will be in the global namespace!  No Lint check for this either, unlike the ERRGLOBAL for let()/prog().
      • Can't change the "current namespace": there is no equivalent to Common Lisp's in-package().  The global namespace is always the current one, which makes SKLL namespaces significantly less pleasurable to use than CL packages.
      • Implementation is immature: it's easy to make Virtuoso core dump when playing around with namespace functions.
      • Can't programmatically get a list of all symbols in a namespace.
  • Name Prefixing
    • Pros:
      • Time-tested, traditional "solution" to the namespacing problem.
      • Easy to understand.
      • Well documented in the SKILL manual and the Emacs Lisp info docs (Emacs Lisp uses a similar convention.)
      • No risk of crashing Virtuoso.
    • Cons:
      • Doesn't really solve the name collision problem: names can still collide if two programmers happen to choose the same prefix.
      • Names become longer and harder to read than with namespaces or environments.
      • Need to take care to enumerate local names in a let() or prog(), though Lint is available to check if you forgot any.
      • No builtins for importing, exporting, and shadowing, though you can roll your own.
Discuss. :)
    Tom,
    As I said in reply to your earlier post about namespaces, in my opinion they are not ready for the prime time yet. I did some investigation of them prior to the release of IC616, and have also given some feedback to R&D about some of the issues with them. My preference would have been that we'd not released them in IC616 because I don't think they're yet in a state that they can really be used to solve real-world problems, and that would have given us more time to mature the implementation prior to making it public.
    Because of this, it needs further discussion and probably not in a public forum because we need to come to a concensus on what we actually need to do.
    You've also directly contacted a few of us directly. Jim (who is in my team) has also been looking at namespaces in more detail over the last couple of weeks and will reply to your private email.
    Kind Regards,
  • tweeks
    Thanks Andrew.
    In that case, I understand if you want to remove this thread.
      --tom
    Tom, no problems with leaving this here. Maybe will come back to it once we have that concensus! Your post is a useful summary of the current status...
