  3. how to translate a rod document into a layout cellview
  • Views 15353
danglang
danglang over 12 years ago
i'm a beginner of skill&rod, i've wrote a skill file using rod functions. how could i translate it into a layout cellview using IC5141.
thank you
    I don't understand your question. If you write a function or script containing rod functions to create shapes, then this will create shapes in the layout view. It's not a matter of "translating" it into a layout cellView.
    So I just don't understand what you're asking because it doesn't really make sense. Could you clarify or give more details?
    Kindest Regards,
  • danglang
    with the "Pcell" function of Virtuoso Layout Editor, you can complile a pcell named "xxx"  into a skill script named "xxx.il", then you type load("xxx.il") in the CIW, you get a pcell.
    if you understand what i just talked above, then you may understand my former question.
    I've wrote a script named "xx.il" including some ROD functions, then how could i get the layout view?
    thank you.
    I must be missing something here. If you have function calls in a SKILL script, and you want to execute them, you use load("filename.il"). You already mentioned that. If the file contains rod functions that create layout, then loading that file will create the layout shapes.
    Maybe you're missing the fact that you need to create the layout cellView in the first place before creating the shapes? So something like:
    cv=dbOpenCellViewByType("myLib" "myCell" "layout" "maskLayout" "w") ; "a" if you want to append rather than overwrite
    rodCreateRect(?cvId cv ?layer "Metal1" ?width 1.0 ?length 2.0)
    dbSave(cv)
    dbClose(cv)
    I'm assuming the answer can't be that simple - so I'm guessing there must be something missing in what you're asking?
