  3. How can I know task is completed or in progress once it...
  • Views 15435
How can I know task is completed or in progress once it is entered into batch mode.
Venu Ch
Venu Ch over 12 years ago
Hi All,
I am running below code in batch mode. It will run DRC in batchmode. It will take 10 mins. I just want to print "completed" in CIW once it is done.
 How can I know task is completed or in progress once it is entered into batch mode. ipcGetExitStatus(cid) is there but is giving current status only.
TMPVAR = buildString(list("perl" " " "strOut.pl" " " cv~>cellName " "
 cv~>libName " " cv~>viewName " " ) "")
printf(
"****************************************************************** \n
**************************RUNNING ViaRedunDency ***************************** \n
cid=ipcBeginProcess(TMPVAR "" nil nil nil "ls.log")
ipcActivateBatch(cid)
ipcActivateMessages(cid)
Thank you,
Chandaka.
    Chandaka,
    Use an exit handler function. For example:
    procedure(MyExitHandler(cid status)
      printf("CHILD %d exited with status %d\n" cid status)
    procedure(MyStartLS()
      let((cid)
          cid = ipcBeginProcess("ls -lR /" "" nil nil 'MyExitHandler
                                           "/tmp/ls.log")
          cid
    If I then do:
    trial=MyStartLS()
    and then after a while I do:
    ipcKillProcess(trial)
    I'll then get:
    CHILD ipc:12 exited with status 0
    You'd get the same thing when the child process finishes normally.
  • Venu Ch
    Thanks alot Andrew for breif discription. It is simply super. Now I can able to know when it is completed.
    Chandaka
