  3. skill func for exporting csv
  • Subscribers 152
  • Views 26565
ASICnm
ASICnm over 12 years ago
I want to export the csv data for my plotted waveforms from the viva XL waveform viewer using skill functions. I have tried ocnPrint and ofcourse it works fine, but want to do so using Skill (that runs behind Trace->Export ; which could also be used, but I prefer the script way.. ).
 This post is motivated fromt the previous post, which does a slightly different versin, as far as i see:
 www.cadence.com/.../1333662.aspx
 Cadence version is IC615.500.14
 Kind Regards,
Aamir
  • tweeks
    tweeks over 12 years ago
    Have you tried this?
    sevExportOutputsToCSV(sevSession)
    => t | nil
    Exports the outputs specified in the ADE setup to the CSV file.
    Tom's suggestion will save the output expressions to a file (and prompts you where to save them), so that's probably not quite what you want - it doesn't save the actual waveform data.
    There's also rdbWriteToFormat() which is like the export capability in ViVA but only for signals in the results browser - not for the results of calculations.
    Something like this might help. There's a CCR requesting an API to write waveforms to (for example) VCSV, but since there wasn't one, I wrote one. You have to give it the waveform objects (like with ocnPrint), rather than doing it from selected items in the graph, but apart from that it works fairly well. The benefit of "VCSV" format is that you can open it as a database in ViVA later which makes it easier to plot the signals when you reload them.
    /* abDumpWaveformsToVCSV.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 11, 2012
    Modified
    By
    Function to write waveform objects out to VCSV.
    Examples:
    outm=v("/OUTM" ?result 'tran)
    outp=v("/OUTP" ?result 'tran)
    abDumpWaveformsToVCSV(outm outp ?expr '("OUTM" "OUTP") ?file "./dump.vcsv")
                               ?from 1u ?to 3u ?by 0.1u)
    The code should handle families, complex waveforms, sets of waveforms
    where the number of points in each waveform is different. It is
    unlikely to handle waveforms where the data contains strings (no testing
    performed). Also you should be careful about interpolating too few points
    - it uses the sample function which will return a number if there is
    only one sample point.
    Doesn't really have enough error checking in this yet...
    Uses a couple of Cadence private functions: drWaveformGetDimension,
    famGetExpr
    SCCS Info: @(#) abDumpWaveformsToVCSV.il 03/26/13.13:42:03 1.2
    ; Container structure to keep the cleaned signal name,
    ; length, whether it's complex etc
    (defstruct abFamilySignal wave name len isComplex)
    * (abUnwrapFamily fam @optional topName top (level 0) (name "")) *
    *    Convert a family or waveform into a flat list of single     *
    *  waveforms, wrapped by an abFamilySignal container structure   *
    (defun abUnwrapFamily (fam @optional topName top (level 0) (name ""))
      (let (dim sweepName)
        (unless top (setq top fam))
        (setq dim (if (or (famIsFamily top) (drIsWaveform top))
                    (drWaveformGetDimension top)
                    0))
        (cond
          ((and (famIsFamily top) (lessp level (sub1 dim)))
           (setq sweepName (famGetSweepName top level))
           (foreach mapcan sweepValue (famGetSweepValues fam)
                    (abUnwrapFamily
                      (famValue fam sweepValue) topName top (add1 level)
                      (sprintf nil "%s (%s=%Y)" name sweepName sweepValue))
          (t (list (make_abFamilySignal
                     ?wave fam
                     ; the messing with strcat in format is to stop SCCS doing
                     ; keyword substitution!
                     ?name (sprintf nil (strcat "%Y" "%s")
                                    (or topName (famGetExpr top)) name))))
    *    (abDumpWaveformsToVCSV ?file outFileOrPort [?from xVal] [?to xVal]     *
    *                     [?type "linear"] [?by interpStep]                     *
    *                     [?expr listOfNames] [?digits 14]                      *
    *                            wave1 [wave2 ...])                             *
    *    Dump the waveforms passed in to a VCSV (ViVA Comma Separated Value)    *
    *  file. Normally the raw data is dumped, but if ?from or ?to are passed,   *
    *  the data is clipped, and if ?by is passed, it is interpolated with that  *
    * step. Normally ?digits would be left alone. The ?expr argument allows for *
    *                cleaner names to be written into the file.                 *
    (defun abDumpWaveformsToVCSV (@key file from to (type "linear")
                                       by expr (digits 14) @rest waves)
      (let (flattened xVec last port lastRow units name first)
        (cond
          ((stringp file)
           (unless (setq port (outfile file))
             (error "Could not write to file %s\n" file))
          ((outportp file)
           (setq port file)
          (t
            (error
              "?file argument must be a fileName or an open output port - %L\n"
              file)
        ; Convert expr into a list with the same length as waves
        (setq expr
              (foreach mapcar wave waves
                       ; pointless statement to keep lint happy
                       (null wave)
                       ; this is what I really wanted to do...
                       (prog1 (car expr) (setq expr (cdr expr)))))
        (setq flattened
              (foreach mapcan (wave exp) waves expr
                       (abUnwrapFamily wave exp))
        (unless flattened
          (error "No waveforms to dump")
        ; Sample or clip the individual waveforms if the from, to, by
        ; arguments have been given
        (cond
          (by
            (foreach flat flattened
                     (setq xVec (drGetWaveformXVec (getq flat wave)))
                     (setq last (sub1 (drVectorLength xVec)))
                     (putpropq flat
                               (sample (getq flat wave)
                                       (or from (drGetElem xVec 0))
                                       (or to (drGetElem xVec last))
                                       type
                                       by
                               wave)
          ((or from to)
                    (putpropq flat
                              (clip (getq flat wave)
                              wave)
        ; Record the length of each waveform for ease of use and
        ; whether it is complex or not
                 (putpropq flat
                           (if (drIsWaveform (getq flat wave))
                             (drVectorLength
                             0)
                           len)
                 (putpropq flat
                           (and (drIsWaveform (getq flat wave))
                                (eq (drGetWaveformYType (getq flat wave))
                                    'doublecomplex))
                           isComplex)
        ; Output header info
        (fprintf port ";Version, 1, 0\n")
                 (fprintf port ";%s" (getq flat name)))
        (fprintf port "\n")
                 (fprintf port (if (getq flat isComplex) ";X, Y, Y" ";X, Y")))
        (fprintf port "\n")
                                 ";Re, ComplexRe, ComplexIm" ";Re, Re")))
        (fprintf port "\n")
        ; Includes some messing around to ensure that there's an X and Y name
        ; because otherwise ViVA will abort when reading the file
                 (fprintf port ";%s,%s"
                          (or (and
                                (setq name (getq (drGetWaveformXVec
                                                   (getq flat wave)) name))
                                (null (blankstrp name))
                                name)
                              "X")
                          (or (and
                                (setq name (getq (drGetWaveformYVec
                                name)
                              "Y")
        (fprintf port "\n")
        ; Similar messing around to ensure there's an X and Y unit
                          (or (and
                                (setq units (getq (drGetWaveformXVec
                                                    (getq flat wave)) units))
                                (null (blankstrp units))
                                units)
                              "xunit")
                          (or (and
                                (setq units (getq (drGetWaveformYVec
                                units)
                              "yunit")
        (fprintf port "\n")
        ; Figure out the maximum length of any of the waveforms
        (setq lastRow
              (sub1
                (apply 'max (foreach mapcar flat flattened (getq flat len)))))
        ; Output all the data
        (for row 0 lastRow
             (setq first "")
                      (if (lessp row (getq flat len))
                          (fprintf port "%s%s,%s,%s" first
                                   (aelEngNotation
                                     (drGetElem
                                       (drGetWaveformXVec
                                         (getq flat wave)) row) digits)
                                   (aelEngNotation
                                     (real (drGetElem
                                             (drGetWaveformYVec
                                               (getq flat wave)) row)) digits)
                                   (aelEngNotation
                                     (imag (drGetElem
                                             (drGetWaveformYVec
                          (fprintf port "%s%s,%s" first
                                   (aelEngNotation
                                     (drGetElem
                                       (drGetWaveformXVec
                                   (aelEngNotation
                                     (drGetElem
                                       (drGetWaveformYVec
                        ; Seems to require spaces between commas
                          (fprintf port "%s  ,  ,  " first)
                          (fprintf port "%s  ,  " first)
                      (setq first ",")
             (fprintf port "\n")
        ; Close the file if it was passed as a string
        (when (stringp file) (close port))
