  3. Error getting while using sh command
  • Views 15870
Venu Ch
Venu Ch over 12 years ago
Hi all,
 I have below code in test file
 #! /bin/tcsh -f
set PWD = `pwd`
if ( -d $PWD/cds.lib ) then
else
echo "##################"
echo "Message: cds.lib is file"
endif
when I am tring to exicute it it by sh("source ./dummy/test") throgh CIW i am getting below error in terminal.
 ./dummy/test: line 6: syntax error near unexpected token `else'
./dummy/test: line 6: `else'
When I am exicute same code in termnal
 Please let me know what is the problem.
Thank you,
Chandaka
    That's because sh() runs a Bourne Shell not a csh. Your script is using csh syntax.
    You should either use csh("source ...") or make your script executable and directly do:
    sh("./dummy/test")
  • Venu Ch
    Thanks Andrew. It is working now. But is failing when i am tring to run in batch mode.
     TMP2="source test"
    cid=ipcBeginProcess(TMP2 "" nil nil 'SKILL "ls.log")
    ipcActivateBatch(cid)
    ipcActivateMessages(cid)
     I am getting below error in ls.log
    ./test: line 6: syntax error near unexpected token `else'
    ./test: line 6: `else'
    Looks like it is running in sh(). How can I define TMP2 should be sourced in csh
    Thank you,
    Chandaka
    TMP2="csh -f test"
    or if you really want to source it (don't see the point, personally), then it would be:
    TMP2="csh -f -c 'source test'"
