  3. skill substrings replace operation
  • Views 17558
tyanata
tyanata over 12 years ago
I have following question, how can be done in skill following sub-string replace operation:
perl -p -e 's|/folder_level1/folder_level2/[^ ]*/spectre/|\$SOMEVAR/spectre/|g'
Best regards,
tyanata
    Hi tyanata,
    With sourceString as the string you wish to replace:
    pat=pcreCompile("/folder_level1/folder_level2/[^ ]*/spectre/")
    newString=pcreReplace(pat sourceString "$SOMEVAR/spectre/" 0)
    The 0 at the end of pcreReplace replaces all occurrences of the pattern.
    If using IC5141, the pattern is simple enough you could use the old rex functions:
    rexCompile("/folder_level1/folder_level2/[^ ]*/spectre/")
    newString=rexReplace(sourceString "$SOMEVAR/spectre/" 0)
    However, the pcre (Perl Compatible Regular Expression) functions are more powerful.
  • tyanata
     Thanks Andrew!
     I was afraid that skill will not interpret the meaning of
    perl regualar expression, but seems I am wrong.
    tyanata
