  3. Finding all paths in a cell and increase width
  • Subscribers 150
  • Views 20085
Lynks
Lynks over 12 years ago
I never used SKILL before but I decided to put one together to migrate a cell library.
The final piece I am missing is finding all paths on a particular metal layer (e.g. M1) whose width is less than 0.1 um. Once found, I'd like to set the width of all those paths to be 0.1 um. I tried searching a bit but the solutions I found were assuming the paths are selected already. In my case, I am iterating through all the cells in my library and opening the layout view. By the way, when I mention 'paths', they show up as 'path segments' in Layout XL (created by using the wire command Ctrl+Shift+W). I am not sure what the difference is between these two.
Any help on the above (assuming I already have the appropriate cv opened through dbOpenCellViewByType()) would be great.
Aside from that, this forum provided nice solutions for changing metal layers and replacing vias with new ones, and I was able to use them in my migration script.
    thinPaths=setof(shape cv~>shapes member(shape~>objType '("path" "pathSeg")) && shape~>width<0.1)
    thinPaths~>width=0.1
    This will find all the shapes which are either path or pathSeg (the path segments you mention, which are the more modern way of handling connectivity) which are narrower than 0.1um. Then having found that list, it will set the width to 0.1um.
  • Lynks
     Thank you for your fast and helpful reply, Andrew. This solution works. The only small change I made was to constrain it to the M1 layer so I added the condition:
     thinPaths=setof(shape cv~>shapes member(shape~>objType '("path" "pathSeg")) && shape~>width<0.1 && shape~>layerName=="M1")
  • tweeks
    tweeks over 12 years ago
    Another example of the map(filter(...)) pattern!  :)
    One of SKILL's more clever innovations is the inclusion of tradtional logical/set-theoretic operations implemented as variable-binding macros:
    • Quantifiers: forall, exists
    • Filter: setof
    • Map: [foreach] mapcar
    • Reduce: [foreach] mapcan
    (Well, mapcan really only covers the special case of reduce where the operator is append, but it is one of the most common use cases.)
    These macros really add a lot to the expressiveness of SKILL, and since they bind a local variable for you automatically, they often save you from using let/prog to declare one yourself.  E.g., Andrew's code above could also be written:
    foreach(thinPath setof(shape cv->shapes member(shape->objType '("path" "pathSeg")) && shape->width<0.1)
        thinPath->width = 0.1
    Which automatically scopes "thinPath" within the foreach(mapc...), at the cost of an additional level of nesting.
    I could also have used the implicit foreach mapcar of the ~> operator (rather than adding an explicit foreach like you did) by doing:
    setof(shape cv~>shapes member(shape~>objType '("path" "pathSeg")) && shape~>width<0.1 && shape~>layerName=="M1")~>width=0.1
    but for the purposes of explaining it (particular to those who are less familiar with a more functional style of programming), I intentionally broke it into two steps.
  • tweeks
    Yeah, I regularly do the same for my co-workers.
    For years I always wrote my code this way because it was shorter. :)  It's great for one-liners, but it doesn't scale well.  Sometimes I'd end up with code like this:
    foreach(
        foreach(
            foreach(...
        )~>stuff
    The infix ~> is just sort of awkwardly hanging there in the middle of all this prefix nesting.
    Two years ago I switched to using Lisp style so I could take advantage of Emacs' Lisp mode (since I was too lazy to write one for infix SKILL), so now I write
    (foreach ...
      (getSGq (foreach ...
                (foreach ...
              stuff))
    Which I think more clearly reflects the nesting, since it's consistently prefix.
    Using Lisp style also avoids wasting vertical space. I like the way the Emacs Lisp Reference Manual said it:
    Don't make a habit of putting close-parentheses on lines by themselves; Lisp programmers find this disconcerting.
    I too tend to write in Lisp style (and have done so for 20 years or so), for a few reasons. One was that I used to write a lot of C code, and SKILL was different enough from C that I kept making mistakes. Secondly I was somewhat familiar with Lisp and writing in Lisp syntax tended to encourage me to think in terms of Lisp ways of doing things. Thirdly "vi" has a lisp mode (I'm a vi rather than emacs user). Fourthly I'm a bit perverse...
    That said, I do tend to revert to C style when I am trying to illustrate examples or ideas, because I know the majority of the SKILL user-base uses C style and I don't want them to be put off by the "Lots of Irritating and Superflous Parentheses"...
    That said, I do tend to shy away from excessive numbers of close parentheses on the same line - I'm not rigid on this, but I try to consider readability over compactness...
