  3. Do we have any function to copy the cell (includes every...
  • Replies 8
  • Subscribers 150
  • Views 23334
Do we have any function to copy the cell (includes every view)
DesmondLiu
DesmondLiu over 12 years ago
Hi experts,
     I need to find a function to copy the whole cell (include every view) by a single SKILL function.
 But all I found is the dbCopyCellView() to copy certain cellview. Besides I couldn't find the copy cell function shown in CIW while I copy the cell in library manager, it's loading context file.
  Did I miss anything or we just don't have the function to used by users?
Thanks in advance.
    ccpCopy() is the function. Or you can do Right Mouse->Copy over the cellName in the library manager, or select the cell (not the cellView) and do Edit->Copy in the library manager.
  • DesmondLiu
    Andrew,
        Thanks for your prompt response. This does help me a lot.
    Best Wishes,
  • tweeks
    tweeks over 12 years ago
    Sometimes ccpCopy() throws an error if it sees something in the cell CDF it doesn't like.
    Let us know if you see that.
    Not seen that before - if you see that, you should report it to customer support.
  • tweeks
    It's specific to ICADV12.1.  IC616-ISR16 is OK.
    See Case 45416561 and Bug CCR 1133633.
    That was a bug with cdfCopyCDF, not ccpCopy, and was in early ICADV12.1 and IC 616 releases. Was fixed in ICADV12.1 ISR 3 and IC616 ISR1 versions (so the first 616 ISR and the corresponding 12.1 ISR).
  • tweeks
    Well we still have problems with ccpCopy dieing on "invalid CDF entry"s, which makes me believe ccpCopy is invoking cdfCopyCDF under the hood.
    Not sure it does call it because it copies the whole data.dm from the cell and doesn't need to bother itself with the specific properties within the data.dm such as cdfData. It would seem unnecessary to me for it to call this function.
    Also, presumably you're using a later subversion than the one containing the fix, so you ought to report it to cust support as an issue with ccpCopy  so that we can address it.
