  3. image in form: possible?
  • Views 16276
sjoerdh
sjoerdh over 12 years ago
 Hi all,
I'm working ona custom GUI form in a layout in Virtuoso using SKILL. This form is to automate a part of an analoguedesign that otherwise takes a few days work. Since this is done every week (we do tape-out each week of multiple versions) it will save a lot of time.
The values entered in the form fields specify the size of  the components placed: 2 resistors, 1 transistor and a diode. This includes all routing as well. To give the designer a better understanding of which values he/she is entering, I'd like to include an image of the schematic representing the layout that will be generated by this form.
I haven't found anything yet that allows me to put an image in a form (like you can put labels with "hiCreateLabel).
So my question is:
Is it possible to put an image in a form?
Thanks in advance.
Kind regards,
Sjoerd
    Sjoerd,
    You can do this with hiCreateLabel, in fact. The ?labelIcon argument can do this, or you can change them dynamically, as in solution 20242568
  • sjoerdh
    Thanks for your reply. I'll test it next week (some other issues with the form I'm creating) but I'll keep you updated.
    Kind regards,
    Sjoerd
  • sjoerdh
    Thank you very much, I got it working in my form.
    Kind regards,
    Sjoerd
