  3. Fastest way to merge two lists without duplicates
  • Replies 9
  • Subscribers 150
  • Views 23010
zmleitao
zmleitao over 12 years ago
When developing SKILL scripts I find the need to join or merge two lists, while avoiding duplicate items.
E.g.:
list1 = '(a b c)
list2 = '(a d c )
merge_func(list1, list2) -> '(a b c d )
Is there a fast/native way to do it in SKILL that is not the obvious iterative solution?
  • tweeks
    tweeks over 12 years ago +1
    Andrew Beckett said: I think that should be pretty fast Would it be a tiny bit faster to do makeTable('unique t) and then make the test (uniq[elem] && uniq[elem]=nil)? It would save you a call to "null…
    procedure(CCFmergedLists(@rest lists)
      let(((uniq makeTable('uniq)))
        foreach(mapcan lst lists
            setof(elem lst
              !boundp(uniq[elem]) && (uniq[elem]=t)
    I think that should be pretty fast, It's based on an older post I made to uniquify a list. This makes some attempt to preserve the order. I've also made it accept any number of lists.
  • tweeks
    Don't do it this way:
    > artUnique(append('(a b c) '(a d c)))
    (a b c d)
    artUnique is private.
  • tweeks
    If order doesn't matter, you can probably do it even faster than Andrew's:
    > list1 = '(a b c)
    (a b c)
    > list2 = '(a d c)
    (a d c)
    > myTable = makeTable("temp" nil)
    table:temp
    > foreach(element (append list1 list2) myTable[element] = t)
    (a b c a d
        c
    > myTable->? (b c a d)
  • tweeks
    Here is a solution that uses the public function ciUniqueMembers:
    > mapcar('car
             ciUniqueMembers(foreach(mapcan list (list list1 list2)
                                 mapcar('ncons list))))
    (a b c d)
  • tweeks
    Would it be a tiny bit faster to do makeTable('unique t) and then make the test (uniq[elem] && uniq[elem]=nil)?  It would save you a call to "null" and "boundp" in the setof....  Also, I wonder which is faster:
    and(p q)
    if(p q)
    when(p q)
    cond((p q))
  • tweeks
    Here's a solution optimized for small positive integers:
    procedure(merge_small_positive_integer_lists(@rest lists)
        let(
                (vector makeVector(1024 nil))
                result
            foreach(list lists
                foreach(element list
                    vector[element] = t
            for(i 0 sub1(length(vector))
                when(vector[i]
                    push(i result)
            result
    > merge_small_positive_integer_lists('(3 34 63 532 234 23 43) '(3 1 4 1 5 9 2 6 7 3))
    (532 234 63 43 34
        23 9 7 6 5
        4 3 2 1
    You could do a similar thing with characters, storing them in a sparse vector of their ASCII codes.
    I did some profiling with a list of 1 million integers (passed twice to the function). Here's the findings (on my laptop, so not the absolutely fastest machine around):
    1. My CCFmergedLists implementation: 1.85s
    2. artUnique solution: gave up after 170s (so very slow)
    3. ciUniqueMembers solution - only works with strings and has to do some list creation to get into the right format. With a list of a million strings passed twice via append, took 9.6s (uses sortcar inside)
    4. Tom's unordered approach which uses a table: 0.84s
    5. An improvement upon this which uses a foreach loop rather than using append:
      procedure(CCFmergedLists3(@rest lists)
      let((myTable)
          foreach(lst lists
          foreach(element lst myTable[element] = t)
          myTable->?
      This took 0.66s
    6. The optimized for small integers (I increased the array size to over 1million to profile it with reasonable data): 0.95s
    7. Tom's refinement of my ordered solution which uses a table which returns t by default (won't work directly as using uniq[elem]=nil as the second arg to && will always return nil. So I used prog1 instead:
        procedure(CCFmergedLists4(@rest lists)
        let(((uniq makeTable('uniq t)))
              setof(elem lst
                prog1(uniq[elem] uniq[elem]=nil)
      This took 1.45s
    So the winners are:
    Ordered: 7 in the above list (CCFmergedLists4) - 1.45s
    Unordered: 5 in the above list (CCFmergedLists3) - 0.66s
    For two million entry lists, which is probably far bigger than you'd ever use this for, these should be good enough (as was my original solution - the others are not massively faster). Maybe small optimizations here and there could be made, Also your mileage may vary with different input data for profiling...
  • tweeks
    I know it's an old thread, but I wanted to say "Thank you!" Andrew for taking the time to profile all these.  The results are quite interesting!
  • Dushyant
    Dushyant over 7 years ago in reply to tweeks
    when and and constructs seem to be the fastest, beating others by about 10%:
    measureTime (for i 0 100000000 (if 1 2))
    (2.041689 0.0 2.070708 0)
    measureTime (for i 0 100000000 (if nil 2))
    (1.885713 0.0 1.885655 0)
    measureTime (for i 0 100000000 (when 1 2))
    (1.838721 0.0 1.838768 0)
    measureTime (for i 0 100000000 (when nil 2))
    (1.666747 0.0 1.666091 0)
    measureTime (for i 0 100000000 (and 1 2))
    (1.84172 0.0 1.8418 0)
    measureTime (for i 0 100000000 (and nil 2))
    (1.670746 0.0 1.671489 0)
    measureTime (for i 0 100000000 (cond (1 2)))
    (2.03869 0.0 2.036863 0)
    measureTime (for i 0 100000000 (cond (nil 2)))
    (1.928706 0.0 1.92704 0)
    Dushyant
