  3. Bug with dbLayerAndNot ?
  • Subscribers 150
  • Views 15232
lkphoto
lkphoto over 12 years ago
I was wondering if there is a known bug with dbLayerAndNot. Indeed, if I write:
Diff = dbLayerAndNot(CellView list("diffphot"     "dataprep") ShapesB ShapesA NumVertices)
then I do not get all the “difference shapes” but just a random subset of them.
Instead, if I simply write the command twice:
then everything works fine.
Length of ShapesB, ShapesA is the same, before, after one call and after two calls. Length of Diff is the same
after one or two calls -still not all the shapes appear in Layout L.
I cannot share the entire code unfortunately, but I may upload a layout + example code (need to create one).
The error might depend from setting NumVertices = 10000. The error appears completely irrational after several debugging attempts.
I am using IC6.1.6.101
lkphoto
    I don't know of a known bug, so I think I'd need to see something that shows the problem. If you can't share it here, please go to support.cadence.com and log a case so that we can take a look.
  • theopaone
    theopaone over 12 years ago
     It's only a guess but the NumVerticies may contribute to your problem. Have you tried using something smaller like 1024?
     Ted
