  3. defvar in SKILL++
  • Views 15953
defvar in SKILL++
tweeks
tweeks over 12 years ago
From the SKILL Language Reference:
defvar(
s_varName
[ g_value ]
=> g_value | nil
(SKILL mode only) Defines a global variable and assigns it a
value. Use the define syntax form to define global variables
in SKILL++ mode.
The "SKILL mode only" qualifier makes it sound like you get undefined behavior in SKILL++.  What you actually get in SKILL33.00 is the usual lexical binding, as with define:
ILS-> (defun foo (x) (defvar y 3) (times x y))
foo
ILS-> (foo 2)
6
ILS-> y
*Error* eval: unbound variable - y
The sentence, "use the define syntax form to define global variables in SKILL++ mode," seems to be more of a coding style recommendation than a technical limitation, since define and defvar are essentially identical in SKILL++.  (Also, neither define nor defvar bind in the toplevel environment unless they are evaluated in the toplevel environment.  The description almost makes it sound like you can use define like defglobalfun--a sort of "defglobalvar".)
So when it says "SKILL mode only", is it really saying that the dynamic-scope semantics you would expect from CL are only available in SKILL mode?
Or is it saying, "don't depend on the current behavior of defvar in SKILL++ mode, because we might change it someday"?
Also, why isn't the third argument (the docstring) documented?  What happens if you provide a docstring?  It would be cool if you could use defvar to provide finder-style documentation!
    I think it's just a mistake in the documentation. Please contact customer support to get it fixed - I'd also thought it misleading but it never got to close enough to the top of my list of things to do to get this one sorted.
  • tweeks
    Thanks Andrew.
     Case 45624417 filed.
