  3. How to add a pulldown menu to All layout windows
  • Views 16004
harishgurram
harishgurram over 12 years ago
I have created a menu, while i am trying to add it to a window with out opening any cell view. It is not adding.
So I want to add my menu to the layout window i opened.
Is there any functions to get the ID of the layout windows only.
    Normally you'd do this using deRegUserTriggers() and registering a userMenuTrigger for "maskLayout" (and maybe "maskLayoutXL"  and "maskLayoutGXL" as well).
    But if you're trying to do it for existing windows - you can find the existing layout windows with:
    layoutWindowIDs=setof(wid hiGetWindowList() rexMatchp("^maskLayout" deGetViewType(wid)))
  • harishgurram
     Thanks Andrew,
    This works fine when there are opened windows.
    But I want add this menu item when ever I open my layout window only.
    OK, so you want the opposite of what you said in your first post - you said you wanted to add it without opening any window...
    Anyway, that's what deRegUserTriggers is for (I mentioned that in my reply too). There are numerous mentions of this in the forums (use Community Search and search for deRegUserTriggers). You need to define a userMenuTrigger function which returns a list of pulldown menus, and then register this function to be called the maskLayout view type.
