  3. How to extract the RegExp matched digit and take it as a...
  • Subscribers 150
  • Views 17341
How to extract the RegExp matched digit and take it as a variable?
DesmondLiu
DesmondLiu over 12 years ago
Hi experts,
    I now have a matched pattern like  comPat1=pcreCompile("[_][0-9]$") but I want to extract the number as a variable and
add one on it (e.g. "_1 " -> "_2", "_2" -> "_3", etc.). How can I do this? I didn't find any related function in PERC/Rex functions.
Is there any way to do this?
Thank you in advance.
Best Regards,
  • tweeks
    tweeks over 12 years ago
    let(
            (string "net_1")
        rexReplace(
            string
            printself(
                1 + atoi(
                    begin(
                        rexCompile("\\([0-9]+\\)$")
                        rexExecute(string)
                        rexSubstitute("\\1")
            0
  • DesmondLiu
    Thank you tweeks, you're helping me a lot !
    It's an elegant coding example. :P
  • tweeks
    Do I detect a note of sarcasm? :)
    SKILL's regular-expression interface is very low-level for the sake of maximizing efficiency: you can control exactly when the regular expression compiler is invoked.  However, computers are so fast these days that in many applications it doesn't make a perceptable difference to performance if you compile gratuitously.  Therefore, I would advise defining a wrapper procedure to automate the basic pattern of rexCompile, rexExecute, and rexSubstitute that you need to pull out matches from a string.  This can make your code significantly more readable.
      --tom
  • DesmondLiu
    LOL, maybe I used a wrong sign.
    This is a great advice, I'll try to find some frequently used function and wrip it up.
    Nice to know some advanced techniques.
