  3. Method to Add table as a property to the view
  • Replies 7
  • Views 17667
Saikrishna14
Saikrishna14 over 12 years ago
Hi
I have used the function dbCreateProp and i could add strings as properties to the views.By using for loop,i have tried to add the individual key value pairs as properties to the view.I am looking for a way to add an entire association table consisting of key value pairs as a property to the view instead of doing each key value pair as a separate property.Could you suggest a way for me to do so? The main reason for avoiding eack key value pair as property is that the number of key-values in the table is very high and there is also a chance that the values corresponding to the key might be altered/tampered.I want the values to be fixed and unchanged.
I should also be able to access the key value pairs of the table (added as a property) later at some point of time.
Regards!
Sai Krishna
    You can't store data structures such as tables in a cellView property - they are constrained to int, float, string, time, and list types (there are a couple of others, but these are the main types).
    However, you can effectively serialize the table to a list to store it, and vice versa to restore it.
    Assuming you have a table, myTable - you can do:
    dbCreateProp(cvId  "myTable" "ILList" tableToList(myTable))
    or you could just use:
    cvId~>myTable=tableToList(myTable)
    then to convert it back to a table later, you'd do:
    myTable=makeTable('mytab nil) ; default value as second argument - whatever you used when creating it
    append(myTable cvId~>myTable)
    If you append an assoc list onto a table, it adds them as key-value pairs.
  • Saikrishna14
    Hi Andrew
    Thanks a lot for the prompt reply.I have tried this as soon as you replied and it worked perfectly well.I have been trying to add the property in such a way that in case the user goes to the view and to the properties(Shift+Q), the property should be seen as read only and user shouldnt be able to write/edit the property.In other words, it should be greyed out.I have been  searching for such a function but couldnt get a specific one.Is there a way?
    Regards!
    Sai Krishna
    Sai,
    Not sure there is. There isn't anything in the database to do this, but potentially there might be some UI capability to restrict this.
    Is this schematic or layout? Which version of the IC tools are you using?
  • Saikrishna14
    Hi Andrew
    I am adding properties to the extracted view as soon as it is getting created.I am adding a table after converting it into a list.The main intention here is that the list which is added as property shouldn't be edited/changed.So that is why i want it to be greyed out (or make the value of the property just  "readonly")so that user cannot tamper the list.Not only the property i am adding,but also  other properties like lastSchematicExtraction, calibre, calibreview_setup,connectivityLastUpdated,PinMap property values can be changed.The properties can also be Deleted or Modified.The Property which i am adding shouldn't be changed.
    Regards!
    Sai Krishna
    And the version you're using is?
    Actually, don't think I need this. I had a quick look in the code for the IC616 edit properties form for layout, and I don't believe this is possible. The properties are all editable and I don't think there's a way to turn that off.
    You'd need to request this as an enhancement via customer support.
  • Saikrishna14
    Hi Andrew
    I'm using IC 616 ISR7.
    Ohh.Is it?Thanks for your time
    Sai Krishna
