  3. Is there a SKILL conversion function from Pinlist to Veriloga...
  • Views 16059
Is there a SKILL conversion function from Pinlist to Veriloga view?
Thib
Thib over 12 years ago
Hi all,
In my former job I used to create veriloga models starting from the symbol of the block I wanted to modelize. From the symbol view,  I used the "Create->Cellview from cellview" menu, typed veriloga in "To view Name" field and it did select automatically the VerilogA Editor item in the Tool/Data Type selection list. Then by pressing ok I created a veriloga view with an empty module which had all the pins from the symbol declared as electrical.
I obtained something like this:
`include "constants.h"
`include "disciplines.h"
module whatever(pin1, pin2, pin3);
    output  pin1;
    electrical pin1;
    input  pin2;
    electrical pin2;
    inout pin3;
    electrical pin3;
endmodule
I moved into a new company where this trick doesn't seem to work anymore... First the view Veriloga wasn't choosable anymore within the tool/Data Type selection list. I could bring it back by adding the following line in my .cdsinit file:
 schAddPinListToViewReg( "VerilogA-Editor"  "text.veriloga" "veriloga" "schPinListToVerilog" )
But as I am using the schPinListToVerilog function, the obtained code isn't written in Veriloga but in Verilog... Moreover, the cell type of the created view isn't "test.veriloga" but "text.v, which causes a lot of troubles afterward...
I searched the help and a lot of forums but could only find 3 conversion functions:  schPinListToVerilog, schPinListToSchematic and schPinListToSymbol.
I am however pretty sure that such a function does exist for veriloga as I found an alternative way to proceed: In the library manager File->New->Cell View, then select the cell and type "veriloga" in the cell view field. The obtained view is a text.veriloga cell type and the code is indeed veriloga.
I am not blocked as I found that workaround, but I wonder if someone does know the name of the function used to convert pinlist into veriloga so I could update my .cdsenv file?
 Many thanks!
 Thib
 Edit: I use virtuoso 6.1.5.64b.500.17
    That's a bit odd, because this should be set in the <ICinstDir>/tools/dfII/etc/context/ahdlSck.ini file which should get auto-loaded at startup.
    I just realised why this might be. If they are either loading <ICinstDir>/tools/dfII/samples/schConfig.il or setting the variable schPinListToViewReg (using the example in that file), it probably is clobbering the value in ahdlSck.ini .
    Calling:
         schAddPinListToViewReg(toolName strcat("text." vtextTool) vtextTool ahdlPinListToVtext)
    should fix it (this line is from ahdlSck.ini)
  • Thib
    Thanks for the quick answer, Andrew,
    The fix doesn't work exactly as intended as the parameters passed to schAddPinListToViewReg are in fact variables locally defined within ahdlSck.ini file.
    However, calling the entire procedure from where this line is coming seems to do the job perfectly:
    regVtextTool("veriloga" ?toolName "VerilogA-Editor")
    Thanks a lot again!
    Thib
    Good point - sorry, I didn't test it and answered far too quickly!
    That's a better solution.
