  3. How to hilight a instance in layout.
  • Subscribers 152
  • Views 17848
Venu Ch
Venu Ch over 12 years ago
Hi All,
I have  list of instance ids. I made a pop window which will contain these are all id's. When I am select any one of them then that instance needs to hilight.
  I need to hilight a instance with some marker layer. Please see the some example screenshots how I want.
 1) is like dynemic hilight
Or
2)Hilight happens when we use search command.
Thank you,
Chandaka.
  • Venu Ch
    Dynemic hilight
    You can create "hilight sets" to do this. Search in the docs for geCreateHilightSet - there are examples on Cadence Online Support too.
    There's no way of using the dynamic highlight though - that's really for interactive "potential selection" indication.
  • aparul
    aparul over 6 years ago in reply to Andrew Beckett
    How can I make a label hilight in given rectanglular Bbox  in virtuoso layout ?
    Andrew Beckett over 6 years ago in reply to aparul
    You could write some code to do this? You could use dbShapeQuery to find any shapes on a given layer in the rectangular region, then filter that to find just the shapes with objType=="label", and then create a hilight set and use geAddHilightLabel to add a label to that hilight set (or use geAddHilightFig given the actual label object).
