  3. How to get the coordinates of all instances in the layout...
  • Replies 8
  • Subscribers 150
  • Views 20783
How to get the coordinates of all instances in the layout hierarchy ?
marbs
marbs over 12 years ago
 Hi All,
 I would like to ask , how to get the coordinates of all the instances in the layout
 hierarchy by using SKILL ?
 I use IC616 .
 Best regards,
 Marben F. Orallo
    Marben,
    procedure(CCFgetInstanceNamesAndCoords(master @optional (transform list(0:0 "R0" 1)) (hierInstPath "/"))
      foreach(inst master~>instances
        printf("%s%s %L\n" hierInstPath inst~>name dbTransformPoint(inst~>xy transform))
          inst~>master
          dbConcatTransform(inst~>transform transform)
          strcat(hierInstPath inst~>name "/")
      t
    Or something similar.
  • marbs
    Thank you very much for the prompt reply.
    The coordinates are correct.
    But how can I get all the cellname of the instances in the hierarchy to display with their coordinates ?
    because the output is like these :
    /|I37/|I0/|I0/|M2 (449.205 213.005)
    /|I37/|I0/|I0/|M1 (449.205 214.145)
    /|I37/|I0/|I0/|M4 (449.205 210.725)
    I want the output is just like these :
     /|vref003c/|vref003b5/|vref003b5/||M2 (449.205 210.725)
     /|vref003c/|vref003b5/|vref003b5/||M1 (449.205 210.725)
     /|vref003c/|vref003b5/|vref003b5/||M4 (449.205 210.725)
    Please help.
    Best regards,
    Marben
    Marben:
    Change:
    to:
          strcat(hierInstPath inst~>cellName "/")
  • marbs
    The code is now working exactly as I wanted.
     I got now the cellnames in all the hierarchy displaying with their coordinates.
    Thank you very much !!!
    Best regards,
    Marben
  • Charley Chen
    Charley Chen over 12 years ago
    Hi Andrew ,
    I used the code and test my layout , for serval insts is OK , for large layout , it has  the message
    *Error*   dbConcatTransform:   Invalid  transform  -   nil
    How to  fix it ?
    Thank you.
    Charley
    Charley,
    This will happen if you have mosaics. I neglected to include a check in the code:
        when(inst~>objType=="inst"
            inst~>master
      t
    The code above should run, but will ignore mosaics.
  • Charley Chen
    Hi Andrew ,
    This code is helpful , Could you help to consider mosaic not ignore ?
    Thank you,
    Charley
    Charley,
    Rather than writing it (I don't really have the bandwidth to do that today), I'll just give you some pointers:
    • You can iterate over cv~>mosaics to get all the mosaics and you can get the bBox of each.
    • If you have mosaics of cells which have hierarchy underneath, you may want to expand all the sub-instances to give you the effective coordinates of each sub-instance. That gets a bit more complicated, but you could use code similar to that in this recent post to handle all the transformations in a mosaic (the code there handles IC5141 and IC61 because mosaics are represented differently in CDB and OA). You could borrow the mosaic handling part and adapt the recursive call in that.
