  3. how to remove/release virtuoso license within tool
  • Views 4186
kramesh
kramesh over 12 years ago
I want to release the virtuoso  layout license within virtuoso tool.
there is any command for this, which i can give in a script to release the license after my work is completed.
    There is no public SKILL API for this. In IC61X it shouldn't be necessary because once the application is closed, the license should be released - if that doesn't happen, you should contact customer support.
    In IC5141 (and earlier IC61 versions) the Options->License had a "Check In" button (it's not there any more, because it should not be necessary to use this if the tool is functioning correctly in IC615/6).
