  3. read list in file
  • Views 17650
read list in file
nidon2003
nidon2003 over 12 years ago
Hi everyone,
I have a list, such as: test1=list(
                                              list("aa" "bb" "cc")
                                              list("dd" "ee" "ff")
Now, I need to output this list into a file(listFile.log) and then read the list in the file(listFile.log)
Is there a simple way/method to make sure that the list readed in listFile.log is as same as  the initial one?
Thank you very much!
Lee
    Andrew Beckett over 12 years ago +1
    out=outfile("listFile.log") pprint(test1 out) newline(out) close(out) in=infile("listFile.log") test2=lineread(in) test2=car(test2) close(in) test1==test2 ; should return t This will work assuming that…
    pprint(test1 out)
    newline(out)
    close(out)
    test2=lineread(in)
    test2=car(test2)
    close(in)
    This will work assuming that everything in the list can be parsed by reading in its print representation and is exactly represented by the list representation (so be aware of db objects, floats, etc).
  • nidon2003
    Tks a lot, Andrew. It's available!
    Lee
